Prusaslicer, volumetric flow and MMU
Dianos
(@dianos)
When using any multimaterial unit Prusaslicer consider the purge volume flow and filament swap in the preview stats. This compress the useful volumetric scale and makes the reading hard. It is possible to exclude the purging movement from the graph?
Best Answer by JoanTabb:
If you save a copy of your project file
then zip compress the file,
you can then attach the zip file to your next post, and we can have a play with the stetings, to see if we can help you.
Questa discussione è stata modificata 2 years fa da Dianos
Postato : 22/07/2023 1:50 pm
RE: Prusaslicer, volumetric flow and MMU
Postato : 22/07/2023 2:20 pm
1 persone hanno apprezzato
Dianos
(@dianos)
berserkproj.3mf.zip
thanks for the helping hand, here's the compressed project file
Questo post è stato modificato 2 years fa 3 tempo da Dianos
Postato : 22/07/2023 3:03 pm
I am confused, the volumetric flow table in the slices model legend window starts at 67.350 mm3/s even though the
Maximum volumetric flow value is set to 20 mm3/s
I have asked for some one else to look at this value.
Postato : 22/07/2023 10:00 pm
