PrusaSlicer view keeps moving/shifting
MonsieurDesigns
(@monsieurdesigns)
Not sure what happened or what keystroke I hit but everything was fine and the next second the view started to shift on the left side of the screen until it "bumps" to the left side of the window. Depending of the orientation of the plater, it sometimes zoom out.
Restarting the app or downloading a new version doesn't change the behavior. It seems to be a hidden settings.
I recorded the behavior, see movie below.
https://forum.prusa3d.com/wp-content/uploads/2021/08/PrusaBehavior.mp4
How can I stop this and revert to a static view? Thanks.
This topic was modified před 5 years 2 times by MonsieurDesigns
Napsal : 08/08/2021 2:32 pm
MonsieurDesigns
(@monsieurdesigns)
RE: Update: Bug disappeared by itself, then came back…
Not sure if the screen recording is being displayed properly. Here is the direct link.
https://forum.prusa3d.com/wp-content/uploads/2021/08/ScreenFlow.mp4
Napsal : 10/08/2021 8:17 am
os
Never seen this activity.  What computer and os?
Napsal : 10/08/2021 9:36 am
I've seen that when the calibration on my attached spacemouse goes out of whack.  Basically it starts treating centre as if its moved slightly and so you get a drift.  Running the calibration routine fixes it.
If you dont have a spacemouse or similar on your pc then I have no idea.  Does your mouse have any other input functions like a thumbstick ?
Napsal : 10/08/2021 11:47 am
Ulfiboy
(@ulfiboy)
RE: PrusaSlicer view keeps moving/shifting
Hi MonsieurDesign and others,
this problem (if I understand it right) is not likely to be a "slicer" problem. I just had the same beavior: The "view" of slicers print bed kept zooming in without any reason or interaction by me. I noticed the same obscurity when I opende the file manager. All directorys were scrolling downwards without any mouse action.
Pulling the "bloototh" USB-receiver out and pluging it back in solved the problem. Strangely enough a complete Win 10 "shutdown" and "restart" didn't work.
Hope that helps.
Napsal : 26/09/2024 2:06 pm
