PrusaSlicer STEP file import buggy?
imhavoc
(@imhavoc)
I have attached a STEP file exported from OnShape. When importing into PrusaSlicer, it renders with some bad artifacts. I tested the file in other 3D software, and the file appears to be good.
I'm attaching the exported STEP file and screen shots from OnShape and PrusaSlicer 2.7.1
STEP file reimport screenshot
PrusaSlicer 2.7.1 import
original model screenshot
Este debate ha sido modificado el hace 2 years 3 veces por imhavoc
Respondido : 16/02/2024 3:59 pm
imhavoc
(@imhavoc)
RE: PrusaSlicer STEP file import buggy?
.... uhm. I'm not seeing the embedded images or the attached STEP file.... If I click to edit, they show up.
Respondido : 16/02/2024 4:03 pm
Hiya.  First of all any files attached except for pictures need to be ZIPPED format.  Or the forum doesnt accept them.  So none of your files made it.
Secondly this is a user to user forum.  All issues and bug reports need to be made over on the Prusa Slicer github.  That is located here https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+bridge+overlap+sort%3Aupdated-desc
Files there also need to be zipped anyway.  Please follow the guidelines when opening a new issue and please please check both open AND closed issues for any possible duplicates before hand.
For example searching for STEP has 45 open issues and 62 closed.  Looking at the list there are several that concern step import.
Respondido : 16/02/2024 4:06 pm
imhavoc
(@imhavoc)
Screenshot original document:
Respondido : 16/02/2024 4:07 pm
imhavoc
(@imhavoc)
Screenshot PS 2.7.1 import:
Respondido : 16/02/2024 4:08 pm
The one I think is related is this one https://github.com/prusa3d/PrusaSlicer/issues/11501
Respondido : 16/02/2024 4:10 pm
