PrusaSlicer Placeholder/Variable evaluation
TimW
 TimW
(@timw-3)
I am using PrusaSlicer Version: 2.3.3+win64-202107161027
My custom G-code is set up as:
Start G-code
; * Start of TJW code **************************
; Reset speed, extrusion rates, and temperatures
M140 S{first_layer_bed_temperature[0]} ; set bed temp
M104 S{temperature[0]}
M117 {temperature[0]}
Template Custom G-code
; Template Custom G-code
After slicing the exported G-code appears as:
;TYPE:Custom
; * Start of TJW code ********************************
M140 S85; set bed temp
M104 S250
M117 250
;AFTER_LAYER_CHANGE
;4
;CUSTOM_GCODE
In the first instance the Placeholders are evaluated correctly but in the second instance no evaluation occurs.  Is this behaviour correct?  What do I need to do for placeholder/variable evaluation to be performed?
Thanks
Respondido : 30/07/2021 3:19 pm
Ringarn67
(@ringarn67)
@timw-3
Save, zip, and upload project file
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Respondido : 30/07/2021 5:02 pm
2¢ worth
Try enclosing the placeholders in square brackets. Curly braces are needed to evaluate expressions, but square brackets are used otherwise. No idea why it does it differently for layer change versus start gcode, but this is worth a shot.
FWIW - Your layer change example shows setting all layers to the 1st layer bed temp. Is that what you want? The reverse is true for the filament temp in the start gcode.
Respondido : 30/07/2021 5:33 pm
TimW
 TimW
(@timw-3)
Thanks for the [] suggestion.  Unfortunately the placeholders are still not evaluated:
;AFTER_LAYER_CHANGE
;4
;CUSTOM_GCODE
M140 S[first_layer_bed_temperature] ; set bed temp
M104 S[temperature]
M117 [temperature]
The example that I am using illustrates the problem but is not what I actually use.
Thanks again.
Respondido : 31/07/2021 12:18 am
TimW
 TimW
(@timw-3)
Simple project which illustrates the problem is attached.
Shape-Box
Thanks
Respondido : 31/07/2021 12:24 am
TimW
 TimW
(@timw-3)
I have created a very simple model and modified the default Printer Settings/Custom G-codes.  It seems that evaluation of Placeholders occurs correctly for:
Start G-code
End G-code
Before layer change G-code
After layer change G-code
But there is no evaluation of Placeholders for:
Color Change G-code
Pause Print G-code
The model I am using to illustrate the problem is: Placeholder_eval
Thanks for any help with this.
Respondido : 31/07/2021 11:03 am
I'm seeing the same. I'd open up a bug report ticket on Prusa's GitHub pages to get developer attention. This is only a user-user forum and the devs only pop in occasionally.
Respondido : 31/07/2021 3:44 pm
TimW
 TimW
(@timw-3)
bobstro, thanks for making the effort to reproduce the problem.  I have opened an issue on GitHub,    https://github.com/prusa3d/PrusaSlicer/issues/6760 , and will post any response back here.
Respondido : 31/07/2021 7:05 pm
1 les gusta
TimW
 TimW
(@timw-3)
This issue has been confirmed.
"I think this a duplicate of #5782 which was fixed on master in 224f3e5. But there have been several duplicate reports already so perhaps the fix could be considered for cherry-picking into stable."
Hopefully we will see a released fix in the near future.
Respondido : 05/08/2021 10:07 pm
1 les gusta
