Prusaslicer on Steam Deck.
Hi
First off I’m a total Linux noob. I installed PrusaSlicer through the discover store but it won’t start.
Any tips?
RE: Prusaslicer on Steam Deck.
How are you trying to run it? If you haven't done so yet, open a terminal window and try running prusa-slicer from the command prompt. If it doesn't work, post here any output from running that command.
Hello,
I have same issue, both with flatpak (discover) and appimage version. The issue is with locale settings. If I use default (en_us), flatpak version starts normally. But my settings is Germany - English (en_DE), and in that case I get following konsole output:
(deck@steamdeck ~)$ /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=entrypoint --file-forwarding com.prusa3d.PrusaSlicer @@ %F @@ -------------------------------------------------------------------------- Message: 09:00:37: Starting PrusaSlicer flatpak with entrypoint script -------------------------------------------------------------------------- /app/bin/entrypoint: line 12: warning: setlocale: LC_ALL: cannot change locale (en_DE.UTF-8) Message: 09:00:37: WARN: Executing prusa-slicer with locale workaround en_DE.UTF-8 (deck@steamdeck ~)$ [2022-10-08 09:00:38.017883] [0x00007fa9a05739c0] [trace] Initializing StaticPrintConfigs An error occured while setting up locale. You may need to reconfigure the missing locales, likely by running the "locale-gen" and "dpkg-reconfigure locales" commands. PrusaSlicer will now terminate. locale::facet::_S_create_c_locale name not valid (deck@steamdeck ~)$
My workaround is to set regional setings to US - American English (en_US), and in detailed settings each one to en_DE (screenshot attached)
I've seen this issue with some other programs in the past, on regular linux distros
Thanks that worked for me to.
But only on the flatpack from discover store. If i download from prusa I get the locale message
