PrusaSlicer on IpadOS?
Pagina 1 / 3
DJ_Walrino
(@dj_walrino)
It would be great to be able to use PrusaSlicer on the Ipad! 3D design then slice directly from the Ipad and upload with Octoprint! or put send it to a PC or Mac to load it onto a SD card!
Best Answer by xarbit:
This morning I found a Slicer made for the iPad, I’m still evaluating it. But it looks like a start.
I assume it uses Cura as its engine, it is not open source despite that there is a github page.
Link to AppStore:
https://apps.apple.com/app/id1614819811
Link to GitHub:
https://github.com/p3d-dev/Print-To-3D
Postato : 23/10/2019 6:44 pm
4 persone hanno apprezzato
Utenti
RE: PrusaSlicer on IpadOS?
Not available at this time, but I would love to see it on the iPad Pro.
Postato : 23/10/2019 8:34 pm
What are you using to do the 3d design with on the iPad ?
Postato : 23/10/2019 10:01 pm
Sembazuru
(@sembazuru)
I'd be more interested to see Plicer on a RPi4 (run Plicer and Octoprint on the same SBC). I'm more of an Android person than iOS, but I don't see running something like Plicer on a touch screen interface as being very comfortable. It would be even worse than a track pad. But that is just IMHO. I've been wrong before, and I'm sure I'll be wrong again. So, I could be wrong now. 😉
See my (limited) designs on:
Postato : 24/10/2019 12:00 am
What - one mouse button isn't enough?
Postato : 24/10/2019 4:13 am
DJ_Walrino
(@dj_walrino)
@neophyl
Ive been messing with Shapr 3D on Ipad! It is actually super simple. But you cannot export highres STLs without paying for it.
Postato : 24/10/2019 5:09 pm
2 persone hanno apprezzato
DJ_Walrino
(@dj_walrino)
@sembazuru
I feel like with the Layout of PrusaSlicer. It would be very nice for a touchscreen and the Apple Pencil!
Postato : 24/10/2019 5:12 pm
Sembazuru
(@sembazuru)
Posted by: @dj_walrino
@sembazuru
I'm completely unfamiliar with the Apple Pencil, but if it is anything similar to Samsung's S-Pen (used on their Note phones and Tab tablets) then I can see that working in PrusaSlicer. I stand corrected. 😀
Postato : 24/10/2019 6:01 pm
1 persone hanno apprezzato
Nikolai
(@nikolai)
I would love to have it on my iPad. But there is no easy way to port the existing code base of Slic3r/PrusaSlicer to iOS. And once you made the port, you need to maintain it and do the port over and over again.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 24/10/2019 9:31 pm
@dj_walrino
Thanks for that.  Looks interesting but low quality stl output or $20 a month I think I'll pass.  I very rarely do subscription based software and I don't think I'd use it enough to justify that a month.
Postato : 25/10/2019 7:17 am
Nikolai
(@nikolai)
Posted by: @neophyl
@dj_walrino
Same thing for me. Their free license is more or less a demo version. And they have no interest to adjust this license (I asked nicely and got pretty grumpy answer). Looks like they are targeting other users.
Often linked posts:
Real Multi Material
Postato : 25/10/2019 7:36 am
Utenti
I don't like 240 a year.
Postato : 25/10/2019 9:54 am
Kyle
 Kyle
(@kyle-3)
Find a student friend with a school email and Shapr3D is free.  I love it.
Postato : 29/10/2019 12:00 am
Nikolai
(@nikolai)
Posted by: @kyle-r4
You know, it's kind of illegal. It's like find a credit card from you friend and it's free ....
Often linked posts:
Real Multi Material
Postato : 29/10/2019 12:05 am
Sembazuru
(@sembazuru)
Posted by: @nikolai-r
Posted by: @kyle-r4
I'm not sure if it is exactly illegal (depending, of course, on your jurisdiction...) unless you use your friend's email without them knowing it (even then it is probably quite gray area). But I'm sure it is against Shapr3D's TOS. Sort of like sharing Netflix account login with non-family/household members.
Postato : 29/10/2019 12:44 am
Netflix license allows for multiple users.  A student allowing someone to use their credentials for something they aren't entitled to is fraud.
Also - you can check the Sharp licensing terms and see the free copy is for actively enrolled students. It even requires a current school issued photo id.
Postato : 29/10/2019 6:23 am
Drukarex.pl
(@drukarex-pl)
Actually, printing straight from the iPad is possible. I’ve done it with Slicer plugin for Octoprint.
I modeled my model from scratch in Shapr 3D on iPad, then exported the file in high-res .STL , using Safari in SplitView to drag&drop the file straight to Octoprint, which is super easy and fast, without the need for saving .STL file to other locations. Then Slicer plugin shows up, you set it up (it’s surprisingly fast and responsive, especially on mobile devices with a touch screen) and it start printing. It took me a while to set it up correctly, with start and end g-codes, but it works.
It would be lovely to have a decent slicer on the iPad though, especially now, when with iOS 13 or later, you can plug SD cards or thumb drives straight to the iPad.
For everyone interested in using this plugin,  here are my settings for Prusa MK3S (settings probably from Cura profile for MK3S, start and end gcodes copied from PrusaSlicer with one or two lines deleted, because with them it didn't work, slicing profile exported from legacy version of Cura (only .ini format works with legacy plugin for Octoprint). All of this might need some tweaking though.
Start G-Code:
G21
G90 ; use absolute positioning
M82 ; absolute extrusion mode
G80 ; mesh bed leveling
G92 E0.0 ; reset extruder distance position
G1 Y-3.0 F1000.0 ; go outside print area
G1 X100.0 E21.5 F1000.0 ; intro line
End G-Code:
M104 S0
M140 S0 ; turn off heatbed
M107 ; turn off fan
G1 X0 Y210; home X axis and push Y forward
M84 ; disable motors
Legacy Cura profile for MK3S is here
Happy printing!
Questo post è stato modificato 6 years fa 2 tempo da Drukarex.pl
Postato : 30/10/2019 7:21 pm
AndyPants
(@andypants)
+1 for this! how do we ping the developers to see that this is something we want?
Postato : 17/12/2019 10:53 pm
Nikolai
(@nikolai)
@andy-j3
As usual, open a feature request on github ( https://github.com/prusa3d/PrusaSlicer). But don't expect any wonders. It's a pretty big feature request.
Often linked posts:
Real Multi Material
Postato : 18/12/2019 12:27 am
Unteins
(@unteins)
@nikolai-r
Porting PrusaSlicer is two parts
Part 1: Porting the slicing engine and core libraries - this is probably doable today, they appear to be written in C++, which is a valid development language for iOS/iPadOS. There may be some adjustments, but iOS and MacOS and Linux share a lot under the hood - so it is probably not as big of an issue as it sounds.
Part 2: Porting the front end - this is a bit more of an issue - but PrusaSlicer uses wxWidgets for the UI - there is an official wxiOS library which has some of the wxWidgets for iOS, but I'm not familiar enough with either PS of WX to say what percentage is available.
The biggest hurdle is probably just getting iOS/iPadOS setup in the project as a target platform so that development could begin. That requires a pretty good knowledge of PrusaSlicer. If Prusa got the initial project setup, it would probably be possible to get a working iPad version going with community help - thought it might also require considerable work on the wxiOS library too.
Postato : 14/01/2020 11:31 pm
Pagina 1 / 3
