PrusaSlicer How to delete a printer preset in 2.9.2
Barrowboy
(@barrowboy)
Since changing PC and updating to 2.9.2 I accidently added the incorrect profile. Now I cannot remove it and its causing mayhem with my printing....online the imformation has all been superceded with the updated Prusaslicer versions...please help
Opublikowany : 15/06/2025 8:40 am
RE: PrusaSlicer How to delete a printer preset in 2.9.2
If its a system profile you run the wizard again and deselect the one(s) you don't want. If its a user profile or added in afterwards then you get a delete profile icon (big orange X) next to the drop down, next to the Save and Rename icons.
Opublikowany : 15/06/2025 12:15 pm
Barrowboy
(@barrowboy)
That's what I thought...however I have run the wizard and the deleted printer is still showing and appears as the default for each print; I also tried the user profile method and I am not getting an orange X against any profiles including the ones I created.
Opublikowany : 15/06/2025 2:27 pm
Robin_13
(@robin_13)
Look where your PrusaSlicer configuration files are stored.  They are text files, you can manually delete it.  I have multiple printer profiles that are customized for options and can choose them in the slicer.
On my Linux computer they are in ~/.config/PrusaSlicer  Search for the file name of the printer you have on your system.
Opublikowany : 26/06/2025 11:01 pm
