PrusaSlicer dual extruder setup
Neil Baker
(@neil-baker)
I have an IDEX by another brand than Prusa. I have tried a couple other slicer programs and wanted to try PrusaSlicer which i do like with my single extruder printer.
The issue I am having is the X,Y offsets in the slicer configuration settings. I've not had problems with other slicers after watching several videos on the proper setups. With PrusaSlicer, I have not been able to find a detailed video on how to set the offsets. When I slice a multicolor object and send it to the printer one or the other extruders will print in the wrong place.
Can someone explain?
Publié : 27/10/2022 2:15 pm
Membre
RE: PrusaSlicer dual extruder setup
I am not sure it is possible.  Prusa does not make an IDEX.
Publié : 02/11/2022 10:07 pm
towlerg
(@towlerg)
Don't have an IDEX so I've never tried this, if you change Printer settings/General/Extruders to 2 and option to set details for Extruder2. I guess Extruder offset might be helpful.
Publié : 03/11/2022 4:04 pm
towlerg
(@towlerg)
Too late to edit. Hope that works, please post if you get a working solution. I've like the IDEX idea, it seems a good compromise between cost, performance and fast two colour printing.
What printer do you have?
Publié : 03/11/2022 4:13 pm
Neil Baker
(@neil-baker)
After fiddling with it and several tests, I finally figured it out. I actually did not have to do any offsets. I put all axis on 0 and it worked just fine. Other slicers, you have to put offsets in but with prusa, you don't.
Also, I prefer prusa over the other slicers I've tried now for both single and dual extruder printers.
Ce message a été modifié il y a 4 years par Neil Baker
Publié : 03/11/2022 5:22 pm
towlerg
(@towlerg)
I was very surprised to see that for Sovol ate least the IDEX version was the guts of twice as much.
Publié : 04/11/2022 5:19 pm
