PrusaSlicer configurations for multiple computers
Dik Harrison
(@dik-harrison)
Is it possible to use the same PrusaSlicer configurations on multiple computers without having to copy the files between the computers?  I use my desktop computer in my office for designing and test printing, but my laptop in my lab (in the basement) is also used for tweaking the g-code after checking the test print.  I want to use the same configuration files with both machines.  I also often use either machine to tweak the slicer configuration.  I would like to use a location on my network for that configuration setup, but it appears that PrusaSlicer only uses the configuration folder on the machine upon which it is loaded.
Napsal : 04/11/2022 12:26 pm
Just symlink the folder to somewhere central on your network.  As long as you're not editing on both machines at the same time race situations shouldn't occur.
Napsal : 04/11/2022 1:30 pm
Dik Harrison
(@dik-harrison)
RE: PrusaSlicer configurations for multiple computers
Thanks, I'll give it a try.
Napsal : 04/11/2022 3:47 pm
Dik Harrison
(@dik-harrison)
It seems to work, time will tell.  It has been 16 years since I retired from IT and had completely forgotten about symbolic links.  Thanks very much for the help for an old man...
Napsal : 04/11/2022 7:52 pm
jsw
 jsw
(@jsw)
I use PS on two and sometimes three machines.
One is a recent Ubuntu desktop, the one in the office is an aging Windoze 7 machine, and the one in the train room is a Pi 400 (but very seldom do I do slicing on that).
I have not tried to synchronize the configs, but I do have a network share with all of the documents on that.  I seldom change anything from the default configs, so I have so far seen no need to try to sync them.
Napsal : 04/11/2022 8:05 pm
I have used OneDrive successfully with Symlinks and it works like a charm. I assume Dropbox or a NAS will work equally well. Haven't run into any conflicts yet even though I routinely have Prusaslicer open on multiple machines.
Napsal : 04/11/2022 9:06 pm
Reini
(@reini)
I use git with a repo on github where I sync configs to/from. I diectly use the PrussSlicer directory on the local machine as repo, e.g. on Mac it is Library/Applicatio Support/PrusaSlicer on Windows it is AppData/Roaming/PrusaSlicer and on Linux I think it is .config/PrusaSlicer.
Changing a setting leads to a git commit/push which gives me also the posibility to return to an older version.
Some folders gets ignored via .gitignore file, e.g. cache directory.
The files in physical_printer are encrypted with git-crypt on the remote repo at github as they contain the api token for octoprint and gets decrypted automatically on the local machine.
On each machine I want this config I have to config git-crypt (if it isn't already there) and clone/pull the repo.
Maybe this is also an interesting approach for someone else...
Napsal : 05/11/2022 1:34 pm
