Prusaslicer - Change extrusion multiplier for separate objects or models
Wurke 3D
(@wurke-3d)
Is it possible to change the extrusion multiplier for separate objects on the build plate like in Superslicer?  Surely this is a key feature for printer tuning?... and being able to do the entire test in one print makes sense.
Opublikowany : 26/01/2022 2:23 pm
Swiss_Cheese
(@swiss_cheese)
RE: Prusaslicer - Change extrusion multiplier for separate objects or models
@wurke-3d
You can set up and assign multiple extruder's.
I'm not sure where or if it's documented anywhere.  it's easy enough to do, just like in SS.
Regards
Swiss_Cheese
The Filament Whisperer
Opublikowany : 26/01/2022 5:55 pm
