PrusaSlicer bridging direction setup?
MartinD
(@martind)
Hello, i tried to slice special object in PrusaSlicer (2.20), and I got weir results, the bridging direction is across the longer side of hole.
Can I change bridging direction somehow to bridge on shorter side, which makes more sense?
Best Answer by Neophyl:
Yes you can.  Its an advanced setting so you must be in advanced or expert mode to see it.  Its under Print>Infill>Advanced>Bridging angle.  Zero is automatic but if you set it to 180 then that's the same as zero degrees.
Bridging angle is global but you can use modifiers and set different angles to different spots using those.
Publié : 13/06/2020 3:50 pm
2 personnes ont aimé
RE: PrusaSlicer bridging direction setup?
Publié : 13/06/2020 5:10 pm
3 personnes ont aimé
jsw
 jsw
(@jsw)
This one threw me too.
It's almost as if it tries to do the long way.
And, you really need to watch for cases where it may do that.
Publié : 13/06/2020 7:02 pm
Area51
(@area51)
Membre
Did this happen even with the "Detect bridging perimeters" set to on?
Publié : 13/06/2020 10:10 pm
jsw
 jsw
(@jsw)
Posted by: @area51
It's my impression that the 'detect bridging perimeters' has more to do with overhangs than bridges.  Am I missing something here?
Publié : 13/06/2020 10:13 pm
Area51
(@area51)
Membre
Not sure what it exactly does, it is still marked as an experimental setting. Sometimes when PS is using standard solid infill over holes it helps turning this option on and a bridge is used instead. My impression was that it also optimized the bridging direction to keep bridge distance short, but I could be wrong.
Publié : 13/06/2020 11:25 pm
MartinD
(@martind)
Thank you Neophyl!
I missed that option, even I was looking for it before I started thread!
Publié : 16/06/2020 4:48 am
