Prusaslicer adding deretract commands for vase mode prints
WillL84
(@willl84)
I've been having this issue for a long time now and I can't figure out what's going on. I'm trying to print a vase mode part but at each "layer change" PS is adding a deretract command that makes a giant blob at the seam. I don't know why it's even doing layers at all - it's set to spiral vase with zero top or bottom solid layers.
Respondido : 28/09/2025 3:37 pm
RE: Prusaslicer adding deretract commands for vase mode prints
It looks like the bottom layer has holes in it, if these are separate to the perimeter, that section of the model will not be in Vase mode!
Can you post a zip compressed copy of the Project file please
Respondido : 28/09/2025 8:12 pm
WillL84
(@willl84)
There are no holes, the model is designed for vase mode. I've attached the 3MF as requested.
Also it tried to deretract so much and so fast that the extruder grinds the filament when it does it.
Esta publicación ha sido modificada el hace 3 months por WillL84
Respondido : 29/09/2025 9:47 am
I don't see the ,3mf file,
Did you ZIP Compress the 3mf file, and attach the zipfile?
Respondido : 29/09/2025 10:08 am
