PrusaSlicer 2.9.3 Final is out
Do you like the new "Consistent Surface" cooling feature in PrusaSlicer 2.9.3? Poll is created on Sep 16, 2025
Petr Kubiš
(@petr-kubis)
We released the final version of 2.9.3 last week!
Key Features in PrusaSlicer 2.9.3
New "Consistent Surface" cooling: Smarter logic for improved outer wall quality on fast layers.
Short travel acceleration: Reduces ringing by slowing only the shortest travels on external perimeters.
Custom G-code parameters: Define your own variables in profiles for flexible G-code customization.
📌 Want the Full Changelog? View on: Github Release Notes
➡️  Want to Try It new version? Visit:  PrusaSlicer Homepage
Dieses Thema wurde geändert Vor 8 months von Jan Kratochvíl
Veröffentlicht : 16/09/2025 8:51 pm
Daniel
(@daniel-43)
Mitglied
Well, this is awkward. Updated to this version and immediately lost MMU3 functionality on the Core One we're using in the office here at work.
PrusaSlicer workflow is the same, but it consistently fails to generate the actual Change Extruder Gcode when slicing. Preview shows the color changes but the actual code is just a continuous run with Extruder 1.
Tried rolling back to 2.9.2 by downloading that old version installer from the website and it doesn't even have the option for the Core One with MMU3 in the Configuration Wizard (where I know for a fact it was present when I installed that version of the slicer the first time).
What is going on? We need this functionality for the things we're printing at work for 5S projects we're using it for (basically printing tool holders for various tools throughout the machine shop--end mills, etc., with clear labeling with contrasting colors between the main body of the part and the lettering).
Diese r Beitrag wurde geändert Vor 8 months von Daniel
Veröffentlicht : 19/09/2025 6:09 pm
Daniel
(@daniel-43)
Mitglied
RE: PrusaSlicer 2.9.3 Final is out
Tried to delete previous post, but update for fix. Manually nuked installation (uninstall, browse to various folders where installation files/configs/etc. were stored, deleted them) and performed a fresh install and things seem to be back to normal.
No idea how the update process messed up so spectacularly, but going forward we'll just uninstall/perform a fresh install.
Veröffentlicht : 19/09/2025 6:33 pm
Marcin Aleksanderek
(@marcin-aleksanderek)
Mitglied
Can You please tell me which application executable is trying to reach Your server?
I am trying to install this in company but seems like firewall is blocking the connection. I have added the Firewall rules for 3 exes in installation directory but it did not help.
- Downloading resources: Archive Database Manifest(Failed to connect to preset-repo-api.prusa3d.com port 443: Timed out
[Error 28]) <- error
- Update check failed for the following errors <-error
Veröffentlicht : 27/11/2025 9:40 am
Marcin Aleksanderek
Mitglied
Veröffentlicht : 27/11/2025 9:59 am
Matt C
(@matt-c)
Mitglied
I would like to see a change during the printing process.  When a print encounters an error (i.e. filament stuck), we can go in and be allowed to do an in-process head swap.  I'm currently in the middle of a print, sitting at 44% complete.  The printer encounter this very issue, filament stuck.  I am no where near my printer, infact, out of the area and unable to assist in correcting this issue.  I would like to be able to swap the printer head from, say, head number 3 to head number 5 mid-print.  Can that be in the next update?
Veröffentlicht : 17/01/2026 10:08 pm
Sembazuru
(@sembazuru)
Posted by: @matt-c
This would be an ask of the PrusaConnect team, not the PrusaSlicer team. (Yes, you can access PrusaConnect from within PrusaSlicer, but all PrusaSlicer knows is it is serving you a web page. Just like accessing PrusaConnect via your web browser.) I'm not sure how to contact the PrusaConnect devs since they don't appear to have a github.
See my (limited) designs on:
Veröffentlicht : 20/01/2026 11:28 pm
Weirdly enough they do seem to actually read the PrusaConnect section on the forum here.  Unlike everyone else.
Veröffentlicht : 21/01/2026 1:41 pm
