PrusaSlicer 2.9.0 multimaterial prints have an unattached layer floating above the wipe tower?
GGFuzzy
(@ggfuzzy)
I've noticed since I started using PrusaSlicer 2.9.0 that after slicing a multimaterial print I always see a layer floating above the wipe tower at the same height as the final print height. Is this expected, or is it a bug?The circled area shows the floating layer Floating Layer Above Wipe Tower
Postato : 15/01/2025 6:59 pm
RE: PrusaSlicer 2.9.0 multimaterial prints have an unattached layer floating above the wipe tower?
Expected. It’s been reported as a bug so many times on the Prusa slicer GitHub and every time it’s closed as it’s designed to do that. I’ll see if I can find the post later and link it here.
Postato : 16/01/2025 6:08 am
FAQ here https://github.com/prusa3d/PrusaSlicer/wiki/Frequently-Asked-Questions-(FAQ)
https://github.com/prusa3d/PrusaSlicer/issues/1355
Postato : 16/01/2025 11:41 am
GGFuzzy
(@ggfuzzy)
That would be great if you can find it. The floating part ends up being extruded onto the top of the wipe tower like a messy little bird's nest. I'd love to hear the rationale for wasting filament... 😆
Postato : 16/01/2025 11:43 am
miroslav.h4
(@miroslav-h4)
The layer above the cleaning tower has been there for a long time. This is not a waste of filament, the same procedure is used to shape the tips of the filament when changing color before pulling back into the MMU and during lower layers of color change.And if there were color changes up to the total print height, you wouldn't even notice it. This is how it goes into the air, because the extruder cannot return to the last height of the cleaning tower.
Postato : 16/01/2025 5:39 pm
GGFuzzy
(@ggfuzzy)
If I'm reading the posts correctly, the extra filament purge is called 'ramming' and it's intended to shape the end of the filament prior to pulling the filament back into the mmu. Thanks for pointing me to the info, Neophyl and miroslav.h4
Questo post è stato modificato 1 year fa da GGFuzzy
Postato : 16/01/2025 8:26 pm
1 persone hanno apprezzato
tetralite
(@tetralite)
Why on Earth hasn't this been fixed? Bambu Labs' version of this slicer doesn't have this problem. Prusa needs to find out how Bambu fixed this.
Postato : 06/03/2025 6:03 pm
Did you not read the earlier posts and links. It’s not been “fixed” because it is designed and supposed to do that. You may not agree with that decision but that’s the one PRUSA have made. You can always use Bambu slicer if you think it’s superior.
Postato : 06/03/2025 6:32 pm
tetralite
(@tetralite)
Yes, I read all posts, but making spaghetti is not acceptable in 3D printing (unless you want to make spaghetti). Bambu's slicer and Prusa's slicer are both modified versions of the Slic3r slicer -- they are identical except for the GUI layout (and Bambu's doesn't make spaghetti after the final layer).
There's no good reason to dump filament into the air -- very bad practice! Easy fix would be to simply have it purge the last filament onto the purge tower during ramming, like it does on each filament change. That's what it's there for!
Postato : 06/03/2025 7:36 pm
In your opinion.  And that's all it is, an opinion.  Everyone has them.
Also your statement has at least one untruth in there.  Slic3r and PS are NOT the same.  The code base was completely re-written in a different language when prusa changed from Slic3r PE (Prusa Edition) to what they currently use now.  There's very little you can directly copy from one to the other.
Also the lineage is Slic3r>Prusa Slicer>Super Slicer.  After that Bambu Slicer forked PS and also used some of the Super Slicer code.  Then deliberately changed it so the files weren't compatible any more.  Orca did a similar thing and built upon Prusa, SuSi and Bambu.
That's the great thing about open source.  If you don't like how it works you can modify it yourself and change it to make it just how YOU like it.  Put your money where your mouth is, or in this case your time and effort.  I don't know,  if you have enough money you could pay for someone to make the changes for you if you dont want to make the personal effort.  Guess that's what Jo Prusa has done. And we all benefit from it.  Including Bambu.
I'm sure Prusa will be heartbroken if you choose not to use their free software lol.
Postato : 06/03/2025 8:03 pm
tetralite
(@tetralite)
It can be fixed. I repeat my original question: Why on Earth hasn't Prusa fixed this MISTAKE? It IS a mistake. It's sloppy!
Postato : 06/03/2025 8:21 pm
Prusa could easily solve this by continuing the Purge tower to the finishing height but normally the purge tower finishes before the model is full height  to save filament. most people would like to save filament and removing the small amount of poop, caused by the final tip forming actions before the MMU unloads the filament .
Postato : 06/03/2025 8:41 pm
Again thats just your opinion.   Its working as Prusa want it to work.  Not an error, not a mistake.  By DESIGN.  Go open yet another duplicate issue on the Prusa Slicer github if you disagree with them.  I'm done with wasting time on people who wont accept that the world doesn't revolve around them.
Postato : 06/03/2025 8:42 pm
tetralite
(@tetralite)
Prusa Slicer generates and error message about the final layer (in screen capture the top layer is 220), so if Prusa Slicer says it's an error, and you say it's not, then who shall I believe?
Yeah, the world revolves around me! WTF? Not helpful!
Postato : 06/03/2025 9:13 pm
I have MMU3 and I don't get that message for the post print purge, however if there are multiple STL's on the top layer, then that is a possibility, could you please provide the offending .3mp project file, for us to try?
Postato : 06/03/2025 9:21 pm
tetralite
(@tetralite)
It's a 4-color print on an MK3S/MMU2S. The first 4 layers of this 220-layer print contain all the color changes, so layers 5 thru 220 are all the same final color. The slicer obviously thinks the purge tower is 220 layers tall, so the slicer is trying to purge on a 220-layer tower that is only 4 layers tall. The error message is reporting a conflict in the G-code because (besides being an more general error message for multiple events) it is printing in the air instead of onto a part or tower object. Looks to me like the program ignores the actual purge tower height for this final ramming purge, but rather still assuming the purge tower is full height. Seems like it would be a very easy fix for someone familiar with the software.
People have been complaining about this for years. One would think Prusa3D would have fixed it by now.
No one need reply -- I'm just saying that I'm surprised that Prusa3D hasn't fixed this.
Postato : 06/03/2025 10:08 pm
Provide me with a .3mf which exhibits this issue that I can replicate, and I Will escalate the issue
Postato : 06/03/2025 10:27 pm
