PrusaSlicer 2.8 Error on start-up
Tadeusz
(@tadeusz)
Hello,
I keep getting error on PrusaSlicer 2.8 start-up:
I have tried uninstalling -> rebooting PC -> installing again. Still getting error window. As far as I know the PrusaSlicer is working normally aside from this error pop-up.
Best regards,
Tadeusz
Best Answer by _KaszpiR_:
go to the config folder from Help - Show Configuration Folder and move the the content related to RatRig to another location.
also see https://help.prusa3d.com/article/faq-prusaslicer_1789 for paths where the configs are.
Opublikowany : 02/07/2024 10:00 am
_KaszpiR_
(@_kaszpir_)
RE: PrusaSlicer 2.8 Error on start-up
Opublikowany : 02/07/2024 6:25 pm
Tadeusz
(@tadeusz)
Thank you for your answer, although I still had the same error. But your suggestion gave me an idea. I have uninstalled PrusaSlicer again and manually deleted all of the remaining PrusaSlicer folders in both installation path and APPDATA folder. Then I have installed again with just Original Prusa MK4 configuration and the problem is gone.
Opublikowany : 03/07/2024 8:19 am
