PrusaSlicer 2.8.0 - MK4 Original Nozzles no longer supports Prusa Link!!
Cowwolfe
(@cowwolfe)
I had this working where I had one physical MK4 Printer connected on Prusa Link (local connection) with BOTH "Original Prusa MK4 Input Shaper x.xx nozzles" and "Original Prusa MK4 x.xx nozzles (i.e. Not Input Shaper)".
Now it appears that the non-input shaper nozzles are no longer supported Prusa Link, they only support Prusa Connect.  See screen capture for options.
If I add a non-input shaper nozzle from MK4 to my physical printer, the Host Type changes from PrusaLink to PrusaConnect.
I had this working for over a month after I upgraded my MK3s to MK4
Eric Z.
Respondido : 17/08/2024 6:58 pm
Cowwolfe
(@cowwolfe)
I was able to find and restore my original printer .ini file and noticed that the contents are different.  Back to working with PrusaLink again with MK4 (non IS) nozzles.  AGAIN, WHY DID THIS BREAK?
Original File - supports both MK4 (no IS) and MK4 with IS with PrusaLink
Esta publicación ha sido modificada el hace 2 years por Cowwolfe
Eric Z.
Respondido : 18/08/2024 1:38 pm
Niclas
(@niclas)
Miembro
RE: PrusaSlicer 2.8.0 - MK4 Original Nozzles no longer supports Prusa Link!!
I'm facing same problem only after configuration file update to 2.0.3. I set configuration back some days and can continue working.
It works as long as nothing is changed in the printer settings.
Do you have an idea if this is a bug or iz should be like this?
Regards, Niclas
Respondido : 20/08/2024 11:59 am
jefffluhr
(@jefffluhr)
Miembro
I'm having this same issue. What is the fix?
Respondido : 25/08/2024 4:02 am
topanlego
(@topanlego)
Miembro
Same with the Mini/Mini+. Hope there’s a simple fix for this.
Respondido : 30/08/2024 1:34 pm
Dustin Doyle
(@dustin-doyle)
I too am having this issue, I miss Prusa Link from the slicer.
Respondido : 30/08/2024 4:30 pm
