PrusaSlicer 2.6.0 Overlap Default Setting 10%
awarzec1
(@awarzec1)
Hey everyone!
I am printing a box at draft settings and noticed the infill is just touching the perimeters. I slowed to 50% and while improved it is still not filling completely.
I did some searching here and checked my Overlap setting. It is set to 10%. But the weird part is the UI is telling me it is at the default setting, but the hover over details says the default should be 25%.
Does anyone else have this issue? Is this a bug? Did the default value change?
Thanks!
Opublikowany : 30/08/2023 1:19 pm
RE: PrusaSlicer 2.6.0 Overlap Default Setting 10%
The defaults mentioned in the tooltip have no relation to the current settings.  Many of them are holdovers from when PS was still Slic3r.  You are expected to adjust profiles to suit your particular machine/filament setup.  If you find you are commonly changing a setting then save a new custom profile.  Thats what the save function is for.  Don't slavishly rely on profiles that have been created for you.
Opublikowany : 30/08/2023 2:03 pm
1 ludzie polubili
