PrusaSlicer 2.4 is here!
Same Old Shane
(@same-old-shane)
Utenti Admin
Greetings all;
Happy holidays to one and all and just in time, we are pleased to announce that PrusaSlicer 2.4 is out of beta and r/c status is now in the full regular release.
Check out the great article by Miki about the improvements and updates.
https://blog.prusaprinters.org/prusaslicer-2-4-is-here-mmu-painting-improved-supports-and-more_60244/
He also produced a video to highlight the new features as well.
Want it? Of course you do... GO! NOW! get to the download site!
https://www.prusa3d.com/page/prusaslicer_424/
Shane (AKA FromPrusa)
Postato : 22/12/2021 8:45 pm
2 persone hanno apprezzato
MysDawg
(@mysdawg)
RE: PrusaSlicer 2.4 is here!
Working on the download now
Postato : 22/12/2021 9:12 pm
muddymaker
(@muddymaker)
Wow, this is a feature packed release, awesome stuff Prusa.
I love the multi material paint-on feature in particular, absolutely awesome, well done guys.
Postato : 23/12/2021 1:57 pm
Eddy71
(@eddy71)
After updating PrusaSlicer v2.3.3 to v2.4.0 the program does not start on Win7 64bit. 🙁
Postato : 24/12/2021 8:31 am
remington
(@remington)
Win 7 is out of extended support now, so i’d expect things to rapidly stop working in it as win11 rolls on
Posted by: @eddy71
Postato : 24/12/2021 11:37 am
Swiss_Cheese
(@swiss_cheese)
It's running just fine on Win 7 64 for me. Win7 64 home and pro versions, it's also running on Win 8.1. also I have both 2.3.3 and 2.4.0 final running.
I did nothing special just opened it and started running it.
Good Luck
Swiss_Cheese
The Filament Whisperer
Postato : 26/12/2021 11:06 pm
Billzilla
(@billzilla)
There doesn't seem to be an installer for 2.4, do we just drop the new files into the existing folders and that's how it's updated?
Postato : 26/12/2021 11:48 pm
Julius4962
(@julius4962)
Thanks for the software update.
I need to ask why the support mechanism has changed so dramatically?
I have a model of a box that I print with some over hang clips. On the previous version the support material was only on 4 points of the box under the over hang over the support mechanism with the new version of the software there are supports all around the box and the print time has increased by 90mins.
I've tested all the available options for supports and none return the same result as the previous software version.
Any advice appreciated.
Regards,
Julius
Postato : 27/12/2021 7:35 am
Lichtjaeger
(@lichtjaeger)
Posted by: @billzilla
Postato : 27/12/2021 10:26 am
Billzilla
(@billzilla)
Posted by: @lichtjaeger
Thanks - I got the zip file from the Github site and it didn't seem to have an installer.
Postato : 27/12/2021 9:38 pm
SiF1
 SiF1
(@sif1)
Some great new improvements 👍
Can i change the start location of a print with this new version?
I can't seem to find a way to do it in the old version.
Postato : 02/01/2022 12:01 am
Frog
 Frog
(@frog)
Reload from disk doesn't function any more after fixing the model through Netfabb.
Questo post è stato modificato 4 years fa da Frog
Postato : 02/01/2022 4:55 am
cmh
 cmh
(@cmh-2)
Sending a print to Octoprint from PS 2.4 - there used to be a checkbox "Start printing after upload" - that's now gone and there are two buttons - Upload, and "Upload and Print". The default is upload. Prior to 2.4, my workflow was to hit the Send to printer button, change the name if necessary and hit Enter - which would follow my default preference of upload and print. Now my preferred default is a non-default button and I have to either start the print manually or grab the mouse and move it to the new button. It's not a massive thing but it's annoying that I could previously choose my default - and now I cannot. Is there any way to change this default, or any good reason for taking away the ability to have a default?
Postato : 31/01/2022 3:53 pm
You arent the only one with the issue https://github.com/prusa3d/PrusaSlicer/issues/7592   been raised, and been closed.
Postato : 31/01/2022 4:51 pm
cmh
 cmh
(@cmh-2)
Oh, sweet - thanks for pointing that out! Added my +1 on that issue, hopefully they decide to put it back.
Posted by: @neophyl
Postato : 01/02/2022 2:05 am
qqcs
 qqcs
(@qqcs)
How can I report a bug?
Postato : 02/03/2022 10:53 pm
sylviatrilling
(@sylviatrilling)
Posted by: @qqcs
Mk3S+,SL1S
Postato : 02/03/2022 11:07 pm
towlerg
(@towlerg)
You do know that there is a feature of Prusascript that allow you to automatically change the name of the GCode file?
For instance I have  Printsettings/output options/output file name format set to -
PS_[input_filename_base]_[print_settings_id]_{filament_settings_id[0]}.gcode
PS is appended (so I know what slicer was used), print and filament settings are prepended (it that a word?)
Postato : 03/03/2022 3:54 pm
https://help.prusa3d.com/en/article/post-processing-scripts_283913
Postato : 03/03/2022 6:20 pm
HermannSW
(@hermannsw)
PrusaSlicer 2.4.1 was released ...
https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-v2-4-1-released/#post-592573
... I raised an issue of small hickup with 64bit Raspberry PiOS appimage with simple resolution:
https://github.com/davidk/PrusaSlicer-ARM.AppImage/issues/22
Postato : 13/03/2022 8:39 am
