Prusaslicer 2.4 - cannot change thick bridges setting via a modifier
Sp4rkR4t
(@sp4rkr4t)
I have a problematic print at the minute that I'm trying to print in ASA, it has large bridging areas at the base that works well with thick bridges checked in prusaslicer, however there are small overhangs further up that are made extra ugly when thick bridges is checked so I tried applying a modifier to turn it off but the option for thick bridges isn't there. Is this a bug or is there a reason you can't change that setting for part of the print?
Opublikowany : 31/01/2022 7:42 pm
Swiss_Cheese
(@swiss_cheese)
RE: Prusaslicer 2.4 - cannot change thick bridges setting via a modifier
@sp4rkr4t
"Thick Bridges" Is currently only available at the Object level.
This can be worked around, by using height range modifiers, and voodoo magic, but you would need a very good understanding of what Slicer can actually do.
Regards
Swiss_Cheese
The Filament Whisperer
Opublikowany : 31/01/2022 8:59 pm
