Prusaslicer 2.3 rc2 and Sidewinder X1, problem ....
Stránka 1 / 2
Allan Fonroques 🚀
(@allan-fonroques)
Hello, I am trying to use Prusaslicer with my sidewinder X1, but I have a problem ...
I export the gcode on the usb key and I plug it into the Sidewinder, I run the print, and the nozzle moves to the left corner and in front and starts to heat up, the problem is that it is placed against the plate, and risk of damaging it as the temperature rises.
I modified the starting code well but nothing to do, someone even sent me a gcode exporter from prusaslicer and same behavior.
If I take Simplify3D and export a gcode and run printing, it behaves normally, so the problem seems to be PrusaSlicer.
Owning 2 Mk3S, I would really like to use Prusaslicer with the Sidewinder, but I don't understand this behavior ....
I'm lost and to tell the truth, a little desperate ...
Napsal : 07/01/2021 7:01 pm
RE: Prusaslicer 2.3 rc2 and Sidewinder X1, problem ....
FWIW, I am using PrusaSlicer with my Sidewinder X1 and am not having any issues. I am printing via OctoPrint.
Easiest would be to compare the gcode produced by PrusaSlicer and that produced by Simplify 3D. Open each file in a text editor and examine the top 100 lines or so. This will contain the startup gcode, including temps and printing of the prime line.
Have you customized the firmware on your Sidewinder? I have noticed that enabling mesh bed leveling can have an impact on the nozzle position. If I do the 4 corner leveling, then enable MBL, I need to set a Z offset (usually a negative value to lower the nozzle) in my printer settings. If I inadvertently leave MBL enabled before doing the 4 corners, it can really throw things off. Depending on whether and where you enable MBL in startup gcode, this might have an effect similar to what you're seeing.
If you want to zip up a SMALL gcode file from each slicer and attach it to a reply here, we can take a look. It would also be helpful if you would save a 3MF project file in PrusaSlicer, zip it up and attach it to a reply so we can see your settings.
Napsal : 07/01/2021 7:17 pm
Allan Fonroques 🚀
(@allan-fonroques)
@bobstro
Thanks for taking your time for my problem.
Some with whom I have spoken also use Prusaslicer with their sidewinder and that without problem.
I installed this:
https://cults3d.com/fr/mod%C3%A8le-3d/outil/firmware-tft-artillery-x1-france
I don't think this changes the firmware, just the pictures in my opinion.
I am attaching you a Simplify3D gcode (which works) and a Prusalicer gcode where I have the problem.
Attachment removed
Napsal : 07/01/2021 7:43 pm
 A few things stand out...
In Simplify 3D, your startup gcode is using:
M420 S1 Z2 ; Enable ABL using saved Mesh and Fade Height
In PrusaSlicer, your startup gcode is using:
G29; ABL (Auto Bed Leveling)
So in Simplify 3D, you are reading in and restoring the saved ABL values which can include a Z offset. In PrusaSlicer, you are doing ABL but not doing any Z offset. The Z offset is roughly equivalent to Prusa's Live-Z, and offset that is applied after mesh bed leveling. In this case, if your saved values -- those retrieved by M420 -- include a Z offset, that is not being applied in your PrusaSlicer gcode. If that offset is a positive value, it is raising the nozzle away from the glass.
You should be able to identify the saved values by entering M503 into a terminal interface on the Sidewinder. In my Sidewinder output, I have this:
G29 S4 Z-0.02000
That is an offset lowering my "Live-Z" (1st layer nozzle height) by 0.02mm. I suspect yours is a positive/non-negative value.
You're welcome to take a look at my PrusaSlicer start gcode for my Sidewinder. Notice I have at the bottom:
M420 S1 Z3 ; reload and fade mesh bed leveling at 3mm
This reads in my saved MBL (I do it manually) values including the Z offset.
I recommend setting your 1st layer height high enough so that WITHOUT restoring the firmware settings, the nozzle will not hit the bed. Then use a NEGATIVE Z offset in your settings or gcode to make adjustments to the 1st layer height at print time. That way, you won't damage the bed if something occurs in the wrong order. Notice in my current start gcode, I do the prime line BEFORE issuing M420. This is just a personal preference so I know the nozzle is at the right height even if the print is off. I want it set so any Z offset adjustments only LOWER the nozzle. (I learned the value of this approach from using my Prusa printer.)
Napsal : 07/01/2021 8:36 pm
Update: Just to clarify, when my startup gcode includes:
That includes the stored value in:
G29 S4 Z-0.02000
as well as a G29 setting for each ABL test point.
Napsal : 07/01/2021 8:43 pm
Allan Fonroques 🚀
(@allan-fonroques)
I have trouble understanding, I'm new to code.
It would appear that you are acting on the code but one thing is not consistent. IF I modify the starting code, with several different alues, that does not change the behavior of the nozzle which always comes to be placed in the same place, besides, another strange thing, a member send me a gcode file which works at home, on his sidewinder with prusaslicer, but when I print this code on my sidewinder, the nozzle always behaves the same way, namely comes to be placed on the plate, in front, in the left corner and heats up before from the print.
To sum up, whether I change the starting code or use a gcode made by another member (while it works well for him), it has no effect on my sidewinder.
Napsal : 07/01/2021 9:33 pm
Allan Fonroques 🚀
(@allan-fonroques)
  1. ; PrusaSlicer start gcode for Artillery Sidewinder x1
  2. ; Last updated 20200814
  3. M300 S60 P10 ; chirp
  4. M117 Initializing
  5. ; Set coordinate modes
  6. G90 ; use absolute coordinates
  7. M83 ; extruder relative mode
  8. ; Reset speed and extrusion rates
  9. M200 D0 ; disable volumetric e
  10. M220 S100 ; reset speed
  11. ; Set print temps
  12. M117 Heating nozzle & bed
  13. M104 S160 ; set no-ooze nozzle temp while bed heats
  14. M140 S[first_layer_bed_temperature] ; set heatbed temperature
  15. M109 S160 ; wait until nozzle is warm to avoid bed damage
  16. ; Home
  17. M300 S60 P10 ; chirp
  18. G1 Z3 F3000 ; move z up little to prevent scratching of surface
  19. M117 Homing
  20. G28 ; home all axes
  21. ; Present bed for final cleaning
  22. M300 S60 P10 ; chirp
  23. G1 Z3 F3000 ; move z up little to prevent scratching of surface
  24. G0 X155 Y310 F7200 ; Present bed for cleaning
  25. ; Wait for final bed heating
  26. M190 S[first_layer_bed_temperature] ; wait for the bed to heat up
  27. ; Return to prime position and wait for nozzle to heat up
  28. M300 S60 P10 ; chirp
  29. G1 Z3 F3000 ; move z up little to prevent scratching of surface
  30. G1 X0 Y-5 F7200.0 ; go outside print area
  31. M104 S[first_layer_temperature] ; set final nozzle print temp
  32. M109 S[first_layer_temperature] ; wait for the nozzle to heat up
  33. ; Prime line routine
  34. M300 S60 P10 ; chirp
  35. M117 Printing prime line
  36. M900 K0; Disable Linear Advance for prime line
  37. G92 E0.0 ; reset extrusion distance
  38. G1 Z0.2 F3000 ; lower nozzle to printing height
  39. G1 E5 F1000 ; de-retract and push filament to trap ooze
  40. G1 X0 Y-3 F7200 ; move to prime line position
  41. G1 X20.0 E10 F7200.0 ; fat 20mm intro line @ 0.5
  42. G1 X60.0 E3.2 F3600.0 ; thin +40mm intro line @ 0.08
  43. G1 X100.0 E6 F3600.0 ; fat +40mm intro line @ 0.15
  44. G1 E-0.8 F3000; retract to avoid stringing
  45. G1 X99.5 E0 F3600.0 ; -0.5mm wipe action to avoid string
  46. G1 X110.0 E0 F3600.0 ; +10mm intro line @ 0.00
  47. G1 E0.4 F1500; de-retract
  48. G92 E0.0 ; reset extrusion distance
  49. ; Final print adjustments
  50. M300 S60 P10 ; chirp
  51. M117 Preparing to print
  52. ; Adjust extrusion rate if desired
  53. M221 S{if layer_height >= 0.1}90{else}100{endif} ; compensate for thick layer heights
  54. M92 E415 ; compensate for extrusion error
  55. ;M85 S300 ; activate 300-second idle timeout
  56. ; Adjust PID values
  57. ;M301 P14.93 I1.27 D43.27
  58. ;M304 P88.75 I11.17 D176.30
  59. M420 S1 Z3 ; reload and fade mesh bed leveling at 3mm
  60. M117 Print in progress
I add this code in the starting code ( https://pastebin.com/dR48YjZ6), and it looks like it works, the nozzle does not move, it starts to heat up to 160 °
Do you think I can use it without risk?
For information, I am in stock and without BL-touch.
Napsal : 07/01/2021 9:44 pm
Allan Fonroques 🚀
(@allan-fonroques)
I do not understand the increase in temperature to 160 °, then in the Prusaslicer parameters, there are different
Look: http://prntscr.com/wik8hd
Napsal : 07/01/2021 9:55 pm
Posted by: @allan-fonroques
[...] I add this code in the starting code ( https://pastebin.com/dR48YjZ6), and it looks like it works, the nozzle does not move, it starts to heat up to 160 °
It's a 2-step nozzle warmup to prevent oozing. It works like this:
  1. Start heating the nozzle to 160C. This is warm enough to soften filament in case you have some on the nozzle, but not hot enough to let the filament to ooze out of the nozzle.
  2. Start heating the bed.
  3. Wait for the nozzle to get up to 160C.
  4. Raise the nozzle and move it to the back-center of the bed while we wait for the bed to finish heating. This gives you one last chance to inspect and clean the bed. (On the Sidewinder, the bed heats quickly, so this may only be for a moment.)
  5. Wait for the bed to get up to the print temperature.
  6. Move the nozzle back to the home position.
  7. Wait for the nozzle to get up to the print temperature.
  8. Print the prime line and continue the print.
You can remove these lines if you don't like them, but it works very well for me on my Sidewinder X1.
Ah, I thought you had a BL-touch or something similar based on the G29 codes in the Simplify 3D gcode. I see that you only modified the LCD screen firmware, not the Marlin firmware that controls the printer. In that case, you need to adjust the 4 corners so the nozzle is at the right height and REMOVE the M420 line from your gcode (line 59 in your post).
I think your problem is that you're using gcode commands that only make sense if you have ABL. Remove those and you should be OK.
Napsal : 07/01/2021 10:08 pm
Allan Fonroques 🚀
(@allan-fonroques)
Yes i understand better 🙂
which line controls the temperature rise of 160 °?
Napsal : 07/01/2021 10:35 pm
davidsteinman
(@davidsteinman)
You may also need to remove the comments in the startup code.  The buffer fills up and you will lose some commands being sent to the printer.  It usually shows up when printing the skirt.
Napsal : 08/01/2021 4:11 pm
The 160C temperature is set in line 13 of your code posted above:
Disable lines 21-25 if you don't like the bed movement.
Napsal : 08/01/2021 4:16 pm
Posted by: @davidsteinman
One of the under-appreciated features of OctoPrint is that it does "minification" of the gcode before sending it on to the printer. It removes all comments from the gcode stream on the fly.
I haven't had an issue on the Sidewinder with comments in gcode though. The board seems to keep up well. The faster serial speeds probably help.
Napsal : 08/01/2021 4:19 pm
davidsteinman
(@davidsteinman)
I  use OctoPrint also, and I think the problem does not occur with it.  It definitely did when using the USB drive.
Napsal : 08/01/2021 4:30 pm
Ah, I dumped the touch screen and have an SD card reader on the LCD screen that replaced it. I never played with the USB much. I suppose it could be slower. I'm sure the speed of the USB flash drive and SD cards matters as well. I chucked the little USB key that came with the Sidewinder and use Samsung EVO SD cards.
Napsal : 08/01/2021 5:09 pm
Allan Fonroques 🚀
(@allan-fonroques)
@bobstro
I have removed this line, but it still preheats to 160 °
Here is the code I put:
M117 Initializing
; Set print temps
; Home
M117 Homing
G28 ; home all axes
; Adjust PID values
Here's how she behaves now:
It stays in the same position, heats up to 160 °, once the temperature of 160 ° is reached, the nozzle moves to the left corner and in front and slightly lifts the nozzle and heats up to 200 °, and once at 200 ° it starts the print by making a test line.
Here is what I would like to change:
Which does not heat to 160 ° but to the one indicated in Prusaslicer, and which makes a longer and slower test line.
What do you think ?
I attach the gcode to show you.
Attachment removed
Napsal : 08/01/2021 6:36 pm
Allan Fonroques 🚀
(@allan-fonroques)
@bobstro
I'd like to have your opinion please 🙂
Napsal : 09/01/2021 6:55 pm
Problems with the Prusa forums are preventing me from posting the fix. Wordfence keeps blocking my posts.
Napsal : 09/01/2021 8:13 pm
Allan Fonroques 🚀
(@allan-fonroques)
@bobstro
Ha thin, hope this will be resolved quickly, I really need your expert advice.
Napsal : 09/01/2021 8:37 pm
@allan-fonroques - Try this startup gcode.
If you want to slow the prime line down, change the E parameter to a lower value. That is mm per minute (mm per second * 60). For example:
G1 X20.0 E10 F1500.0 ; fat 20mm intro line @ 0.5
Napsal : 09/01/2021 8:59 pm
Stránka 1 / 2
