PrusaSlicer 2.3.0 and SL1 network connectivity
Rob Meades
(@rob-meades)
I've updated to 2.3.0 (release version) but I am unable to make this new version connect to my SL1.  I know the IP address is correct, the SL1 is switched on and displays the same IP address, I have port 8000 and the API key is that which the SL1 displays under its Advance Settings->Login Credentials menu.  The username is unchanged from the default (maker).
Any idea what I might be doing wrong?
Dieses Thema wurde geändert Vor 5 years 2 mal von Rob Meades
Veröffentlicht : 24/01/2021 1:31 pm
Lichtjaeger
(@lichtjaeger)
RE: PrusaSlicer 2.3.0 and SL1 network connectivity
I have the same problem. Because of the error number 400, I assume that this feature isn't implemented in the current SL1 firmware release.
Veröffentlicht : 24/01/2021 10:36 pm
Rob Meades
(@rob-meades)
@lichtjaeger
I think my error is different, a simple timeout (error 28). I'd assumed that PrusaSlicr 2.3.0 used the same printer-protocol as the previous version, which certainly worked with the current version of the SL1 firmware (1.4.2).
Veröffentlicht : 25/01/2021 12:32 am
Rob Meades
(@rob-meades)
Mysteriously, I've just tried it again and it is now working.  Ho hum.
Veröffentlicht : 14/02/2021 4:09 pm
