Prusa startup error on Debian
ramack
(@ramack)
When starting Prusa, I receive the error below. I've installed the package from the Debian Repo. Any ideas on how to resolve?
ConfigBase::set_deserialize() failed for parameter "gcode_flavor", value "marlin2"
System info
Linux 5.10.0-15-amd64 #1 SMP Debian 5.10.120-1 (2022-06-09) x86_64 GNU/Linux
prusa-slicer: Installed: 2.3.0+dfsg-1
Thanks,
Opublikowany : 30/06/2022 11:33 pm
jsw
 jsw
(@jsw)
RE: Prusa startup error on Debian
Have you tried running either/both of the .appimage files directly from Prusa?
Opublikowany : 30/06/2022 11:42 pm
ramack
(@ramack)
After I posted, I found the current .AppImage, DL'd it and it does run without error.
Opublikowany : 30/06/2022 11:44 pm
ramack
(@ramack)
Any ideas/suggestions getting the .deb package running without the start up error?
Opublikowany : 05/07/2022 10:27 pm
ElroyP
(@elroyp)
I get the same error.  I was running 2.4 no issues, upgraded t0 2.5.0.   I cannot launch the app directly without get the same error message:
Running Win 10 / 64 - MSI - Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz 2.30 GHz
Opublikowany : 10/10/2022 2:33 am
ramack
(@ramack)
The only work around I found was to run using the .AppImage. I was only trying the slicer out, never used really used it for generating gcode. Haven't tried to start the app since.
I'm guessing that it's something with a config file, but haven't had the time to troubleshoot.
Opublikowany : 13/10/2022 12:01 pm
