RE: prusa slicer organic supports WAY to far from the supported opject!
Are you using variable layer height at all in the 3mf ? It’s currently not compatible with organic supports.
Respondido : 04/02/2023 11:52 pm
If your using the alpha 3 you can't even have organic supports in the project if any object on the build surface has variable layer height enabled. Instant invalid data making Organic supports worthless. Basically they aren't ready.
Respondido : 05/02/2023 12:23 am
I'm having this same problem but I'm not using variable layer height. I'm wondering if it has to do with the model being scaled in my case.
Respondido : 05/02/2023 11:45 am
