Prusa Slicer Non-Planar
Brian
(@brian-11)
I saw that a YouTuber (Teaching Tech) posted that there was a new version that brought the Non-Planar slicing (that was formerly only available with Slic3r running on Linux) to Windows OS.
I would like to at least try Non-Planar as I have a good use case that should benefit greatly from such.
I wasn't able to get my version to have the Non-Planar option/settings.
 The video that TT posted shows says download the file from GitHub and launch a .exe file from the folder.
I saw no .exe file(s) to do that.
I had a later software than 6.0 but didn't see any executable regardless.
Can anyone here help me to get Prusa Slicer set up with Non-Planar?
Here are links to the TT YouTube video and the Git page.
https://github.com/teachingtechYT/Pru...
Postato : 09/05/2024 10:38 am
BaconFase
(@baconfase)
RE: Prusa Slicer Non-Planar
Download the "Release.7z" from https://github.com/teachingtechYT/PrusaSlicer/releases/
Open/unpack using 7zip and you'll get a folder called Release that has the usual looking stuff.
When you first run the fork you'll get a couple popups. One you just click through, the other tells you that you'll have to redo your printer configs (since you'll most likely be 'downgrading' from 2.7.4 configs back down to 2.6). So you may want to backup some things just in case. So go through the config wizard and you'll get what's shown in the video.
One thing I noticed is the GUI gets (more) wonky looking after switching printers. The workaround seems to be to switch printers first and then just restart PS.
More wonky
More 'correct' i guess:
Also seems the 2.6 config wizard seems to only come with XL 1T and not 5T nor IS of any sort.
Never actually tried printing anything, just checking out the software.
XL-5T, MK3S MMU3 || GUIDE: How to print with multiple-nozzlesizes do read updated replies || PrusaSlicer Fork with multi-nozzlesize freedom || How Feasible is Printing PETG for PLA supports on XL very
Postato : 10/05/2024 12:07 am
Brian
(@brian-11)
Thank You. I had no idea I needed a particular Zip extraction program or what file exactly to download. I had learned that it was only for 2.6 and that should be ok for me. I'm not very current in my experience with Prusa Slicer anyway. I don't know what XL 1T and not 5T nor IS, is sorry.
I'm only resonably proficient at operating a printer.
I do understand that there are issues with the Non-Planar right now. I think it is a good capability to have though and want to see it get continue development in the future.
I'll be giving it a try very soon and post what the results are.
Seriously
thank you again BaconFase
Postato : 10/05/2024 9:22 pm
BaconFase
(@baconfase)
XL 1T = Prusa XL, one toolhead
XL 5T = Prusa XL, five toolheads
IS = Input shaper
Non-planar is really cool, but like he says in the video: you're gonna need a setup where your nozzle hangs down low with ample space around it. I don't think it'll work so well, or at least not usefully, on a stock Prusa extruder setup unless youre planning on printing something already super shallow and doesn't need part cooling. Something like CNCKitchen's redneck volcano setup where you just use a volcano nozzle and a nut or two seems strangely appropriate for this. It might even work better on a Nextruder (adapter) type than the mk3/mini because then you wouldn't even have to worry about pinda stuff. Just remember its basically alpha software so get ready for things to break.
Postato : 11/05/2024 2:20 am
nazar-pc
(@nazar-pc)
Utenti
I think slicer could hypothetically account for default (and allow to customize) shape of things around nozzle to warn user that something will collide with the part being printed.
You'd be able to reorient the part to make it fit sometime.
It would still be useful to be able to print smooth surfaces even if supported slope is fairly limited out of the box.
Postato : 22/06/2024 10:50 am
WenPing Pan
(@wenping-pan)
Utenti
I have a stl model which has very small curved radii and applying non-planar printing technique, I found that the printing result is very poor. Now I don't know how to fix it, do you have any ideas please?
Postato : 18/11/2024 4:01 am
