Prusa Slicer MINI+ system
Mataos
(@mataos)
Hi, I've noticed that when I print on my MINI+ it says that the gcode is not for my specific printer. Is there an option somewhere in PrusaSlicer that I can set it to my MINI+? That way I can confirm whether what I am printing will fit on the bed also. Cheers
Best Answer by Antonio:
on the right tab of prusaslicer you should select the MINI+ printer profile (if not present, you need to add it first with the wizard)
check this guide
Respondido : 06/03/2021 8:38 am
Antonio
(@antonio)
Miembro Moderator
RE: Prusa Slicer MINI+ system
check this guide
I'm not an expert. Ma parlo anche italiano 😉
Respondido : 06/03/2021 8:57 am
1 les gusta
Mataos
(@mataos)
@antonio-da-catania
Thank you, problem solved!
Respondido : 06/03/2021 10:32 pm
1 les gusta
