Prusa Slicer makes more corners than needed
Manu M
(@manu-m)
Slicer duplicates corners where only one corner should be, but only at the first layer:
First picture is from first layer, the second from the second picture. Checked the model for duplicates. I want to print in with Filamentum Timberfill Champagne. (Used good default setting from slicer.) The 3D Model is made from a SVG improted to blender, already removed doubles.
What I tried: change resulotion, changed overlaped, changed extrusion width, open in a new window/project, sliced in cura with different but also no good results.
Best Answer by JoanTabb:
Hi Manum,
could this be caused by Elephants Foot Correction?
Try turning that off (Resetting it to 0.0mm , and re slicing.
Note it's an advanced option, so you need to be in either Advanced, or Expert mode to see the option
Opublikowany : 19/09/2020 7:19 pm
RE: Prusa Slicer makes more corners than needed
Im not sure what your issue is, you are not making yourself clear.  What about those pictures is it that you think is incorrect ?
Please explain exactly what you think is wrong, try marking the areas an explaining what you think it should look like.
Also please save your project as a .3mf from slicer , zip it up and attach it here.  (it must be zipped for the forum to accept the file type for anything other than pictures).  That way we can see exactly what settings you are using, slice it with them and also change things to try and see what effects it gives with the same parameters that you are using.
Also if its a blender file you could include that for completeness, some of us use that too so its another thing that will make it easier to figure it out once we know what it is that is wrong.
Opublikowany : 19/09/2020 10:12 pm
1 ludzie polubili
Manu M
(@manu-m)
@neophyl
Thanks: Quick awnser: The first Picture shows the first layer, the second picture the second layer. I want the first layer with a sharp edge just as the second layer and also just like the stl file I used (flat plate with some letter cut out).
More details later.
This post was modified 6 years temu by Manu M
Opublikowany : 19/09/2020 11:16 pm
Manu M
(@manu-m)
Here are the files, Blend and 3mf.
The Filament settings are the default settings for Timberfill,
Physio3
Opublikowany : 19/09/2020 11:26 pm
jsw
 jsw
(@jsw)
Is this more along the line of what you are expecting?
I re-sliced using .15 resolution and the top of the 'Y' is angular, like I would expect.
Opublikowany : 20/09/2020 12:07 am
Hi Manum,
Opublikowany : 20/09/2020 12:45 am
1 ludzie polubili
jsw
 jsw
(@jsw)
Oops, misunderstood you, sorry.
I turned off elephant foot correction and resliced and the first layer looks good.
Opublikowany : 20/09/2020 1:18 am
Manu M
(@manu-m)
@jsw
I was not sure what you meant with resolution, but what I tried with resolution for edges didn't worked.
@joantabb
Just what I needed, helped by me to thanks a lot!
Opublikowany : 20/09/2020 6:37 am
jsw
 jsw
(@jsw)
It was the .15mm layer detail selection that I happened to have active at the time.
I think that adjusting the elephant foot correction is probably the best solution to the issue.
(I have this habit of replying to this forum and others while multitasking and sometimes I miss things, such as your issue occurring on the lowest layer.)
Opublikowany : 20/09/2020 1:47 pm
