Prusa slicer loosing holes on curved objects
[Risolto] Prusa slicer loosing holes on curved objects
Astroxss
(@astroxss)
Only on curved surfaces prusa slicer is loosing holes ( extruded, or "hole", any size )
Object is created with 1/4 eclipse which is 360 revolved on Z axis.
On flat or sphere objects holes don't disappear.
STL file
Postato : 23/05/2021 6:32 pm
Utenti
RE: Prusa slicer loosing holes on curved objects
There something wrong with that file and it is not repairable.
Postato : 23/05/2021 8:36 pm
How to save and upload a project
Postato : 23/05/2021 11:47 pm
Utenti
Posted by: @astroxss
STL file
I hope this was able to help.
Postato : 24/05/2021 12:54 am
Astroxss
(@astroxss)
kkkk v12_maz
Compressed .3mf file as suggested before
I created another small object with two  holes and  still have same problem with holes disappearing when slicing.
File: another_2hole
Postato : 24/05/2021 7:48 am
Ringarn67
(@ringarn67)
@astroxss
What program did you use?
I opened up the file in Fusion360. It appears the STL-file in your first post is not a solid, it is more like a tent.
One bottom surface with holes and a domed surface with holes.
It is hard to tell by my printscreen, but if you look down through the big hole in the dome you can see the small hole in the bottom, and that should not be possible if it is solid.
There is an example attached that I draw quickly in Fusion 360
Attachment removed
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 24/05/2021 10:20 am
Ringarn67
(@ringarn67)
YES, I know now it´s not a DOME, it is a CONE 😆
But problem is still the same 👍
Postato : 24/05/2021 10:27 am
Astroxss
(@astroxss)
SOLVED:
In fusion 360 used "boundry fill" tool.
It still had problems when slicing ,but "Fix using netfabb" tool in slicer solved that.
Problem was that object was not solid + some manifold problems.
Postato : 24/05/2021 10:50 am
