Prusa Slicer leaves gaps on lines
f16r
 f16r
(@f16r)
Hey Prusa Printer-Community,
when slicing my 3D Model with Prusa Slicer some lines are not end-to-end?
Is this an issue with the model I try to slice or are there some settings to prevent this?
Thank you very much!
Fabian
Best Answer by f16r:
I am new to 3D Printing so I was not aware that it is normal to have a "seam".
In Print Settings - Advanced - Seam position I was able to choose random so that I do not get concentrated gaps in the model. My current print orientation does not allow to hide the gaps. But I will take it into account next time.
Thanks!
Postato : 13/02/2021 11:17 pm
RE: Prusa Slicer leaves gaps on lines
It's hard to say from that picture.  While you are in the layers view, move the slider on the right and check the placement of filament in the cross section of the offending layers, the reason may become clear.
If not, post a picture of the cross section.
Postato : 14/02/2021 2:54 am
f16r
 f16r
(@f16r)
Hey diem,
thank you for your response!
It seems that the gaps are caused at the start/end of the line and it is definitely visible on the print 🙁
Fabian
Postato : 14/02/2021 11:28 am
f16r
 f16r
(@f16r)
Thanks!
Postato : 14/02/2021 1:43 pm
@f16r
Well done.
Postato : 15/02/2021 3:27 am
