prusa-slicer - fail to slice a simple model
Behn66
(@behn66)
Dear all,
 I created quite a simple model with openscad.
However when trying to slice it with latest PrusaSlicer (Version: 2.1.0+win64
Build: PrusaSlicer-2.1.0+win64-201909160915) it fails.
I am using original presets and I am unclear why it finally fails.
The openscad-source-code:
//cr10 - ditan
//nema17 motor stuff
nema17_lochabstand=31;
nema17_radius=1.7;
nema17_seitenlaenge=42;
nema17_hull_radius=2;
nema17_boden_dicke=5;
nema_17_center_hole_dia=24;
//bottom_plate specifics
screw_enlarger_height=5;
screw_enlarger_radius=3.5;
3mm_screw_radius=1.45;
//ditan
ditan_orinal_srew_distance=67.5;
ditan_original_length=80;
ditan_original_height=20;
ditan_mount_thickness=4;
ditan_mount_height=55;
ditan_mount_height_cooling=12; // set to zero to disable
ditan_flatwasher=2.3;
module ditan_holes (radius) {
cylinder (r=radius,h= ditan_mount_thickness+screw_enlarger_height,$fn=32);
translate ([ditan_orinal_srew_distance,0,0]) cylinder (r=radius,h= ditan_mount_thickness+screw_enlarger_height,$fn=32);
module ditan_mount_eine_seite () {
height=ditan_mount_height+ditan_mount_height_cooling;
//cube ([ditan_mount_thickness,ditan_original_length,height]);
difference () {
union () {
translate ([ditan_original_length,0,0]) rotate ([0,0,90]) cube ([ditan_mount_thickness,ditan_original_length,height]);
//loecher_verstaerkung oben
translate ([(ditan_original_length-ditan_orinal_srew_distance)/2,0,height-ditan_original_height/2]) rotate ([-90,0,0]) ditan_holes (screw_enlarger_radius);
//loecher_verstaerkung unten
translate ([(ditan_original_length-ditan_orinal_srew_distance)/2,0,ditan_original_height/2]) rotate ([-90,0,0]) ditan_holes (screw_enlarger_radius);
//loecher
//oben
translate ([(ditan_original_length-ditan_orinal_srew_distance)/2,0,height-ditan_original_height/2]) rotate ([-90,0,0]) ditan_holes (3mm_screw_radius);
//unten
translate ([(ditan_original_length-ditan_orinal_srew_distance)/2,0,ditan_original_height/2]) rotate ([-90,0,0]) ditan_holes (3mm_screw_radius);
module ditan_mount () {
color ("blue") ditan_mount_eine_seite ();
translate ([ditan_original_length,-ditan_original_length,0]) mirror ([1,0,0]) color ("green") rotate ([0,0,90]) ditan_mount_eine_seite ();
translate ([ditan_original_length,0,0]) cube ([ditan_mount_thickness,ditan_mount_thickness,ditan_mount_height+ditan_mount_height_cooling]);
ditan_mount ();
Kindly ask for help whats required to slice it successfully?
thanks
christian
slicing_just_one_side
This topic was modified před 7 years by Behn66
Napsal : 27/09/2019 6:17 pm
RE: prusa-slicer - fail to slice a simple model
could you zip and attach a copy of the STL for this model please?
Joan
Napsal : 27/09/2019 6:49 pm
Joan
Napsal : 27/09/2019 6:50 pm
Behn66
(@behn66)
@joantabb
Dear Joan,
thanks for helping. I created a "simpliefied" version if the STLslice_it_vertically_knob_at_lower.stl
You want to try slicing it this way:
thanks
christian
Napsal : 27/09/2019 7:08 pm
Behn66
(@behn66)
@joantabb
And here is just another fail of the object. I hope the STL-files passed the upload.
many thanks
fail_2.stl
Napsal : 27/09/2019 7:12 pm
Behn66
(@behn66)
Dear Joan,
just adding the print-settings in case it makes a difference.
thanks
Attachment removed
Napsal : 27/09/2019 7:39 pm
Hi Christian,
Your STL is Faulty.
loaded in Prusa Slicer as supplied
Loaded in slicer inverted
loaded in slicer turned 90 degrees
Napsal : 27/09/2019 7:52 pm
when the same model is placed with it's large surface on the build plate, now gives a better but still defective result.
however if you use the Repair STL option
you  end up with a file in .obj format, which you can load into Prusa slicer, and get
A working object... 🙂
Joan
Napsal : 27/09/2019 7:59 pm
Dave Avery
(@dave-avery)
not sure what the problem is but netfabb fixes it
https://service.netfabb.com/service.php
Napsal : 27/09/2019 8:03 pm
BUT you wouldn't normally print in that orientation, it would be more like this
as you can see the four holes are good on the Bottom side
And the 4 bosses, are good on the top side...
Forgive me slicing this with 4 outlines and Octogram Spiral top and bottom infill...   I was using them for one of My models, and just used the same settings for this example.
Napsal : 27/09/2019 8:05 pm
Thanks Christian,
the problem is not your slicer settings, there is an error, or errors in the STL file...   as described above!
Napsal : 27/09/2019 8:07 pm
Behn66
(@behn66)
@joantabb
Dear Joan,
first many thanks for your fast and very useful help. Based on your feeback I checked why my STL is faulty. I realized I had an outdated version of openscad to create the stl. Once I upgraded openscad to latest version slicing works nicely.
So all good now
Again many thanks for this quick help - appreciated
christian
Napsal : 27/09/2019 10:17 pm
 My pleasure Christian,
Napsal : 27/09/2019 11:49 pm
