Prusa Slicer adds volume where a hole has to be (possible bug)
[Rozwiązany] Prusa Slicer adds volume where a hole has to be (possible bug)
Honzinator
(@honzinator)
Hello,
(Sorry if this is not a right place for this issue. I'm novice here.)
I have a simple model with inner hexagonal hole for a nut.
This is how a model looks like
And this is how it's sliced
You can see slightly different colour in the hexagonal hole where is the unwanted surface (volume) afters slicing. Its because there a little collar locking a nut in position.
Prusa Slicer v. 2.3.3 (win64)
STL + 3MF files temporarily available on http://leteckaposta.cz/939562432
It's bug, or am I doing something wrong?
MINI+ owner since 10/2021
Opublikowany : 19/11/2021 10:39 pm
Area51
(@area51)
RE: Prusa Slicer adds volume where a hole has to be (possible bug)
I wanted to look at your files, but give up, trying to download.
Please Zip the files (3mf + STL) and attach them directly to the forum (upload).
Opublikowany : 19/11/2021 11:31 pm
Honzinator
(@honzinator)
Oh, the ZIP does the trick! ( tried to upload files directly here, but they was rejected due filetype restrictions).
STL+3MF file
Opublikowany : 20/11/2021 8:27 am
BogdanH
(@bogdanh)
Your object contains two duplicate vertices. Load STL in Blender, remove the duplicates and save STL -after that object will be sliced as expected.
[Mini+] [MK3S+BEAR]
Opublikowany : 20/11/2021 10:41 am
1 ludzie polubili
Area51
(@area51)
As @bogdanh points out, your STL model is not manifold and have extra geometry. It may look right when shown in PrusaSlicer, but fails when sliced.
Here in Blender, showing some of the extra non-manifold edges in orange:
Using the 3D Toolbox in Blender it can be fixed. I have attached updated project file.
Opublikowany : 20/11/2021 1:27 pm
1 ludzie polubili
Honzinator
(@honzinator)
Thanks for your insight! It's forgotten surface body used as a tool during modelling.
Leson taken. Dissable all surface bodies before STL export.
Opublikowany : 04/12/2021 9:50 am
