Prusa Slicer 2.74 Windows issues
Halde
(@halde)
I just downloaded the latest Prusa Slicer 2.7.4 and read in a GCODE file (rather than a project - long story, but I lost all my projects) - changed the object a little (shortened the x axis size by 25%), and then tried to re-slice it - the Slicer hung at 90% (generating the GCODE).  Shut the slicer down and re-tried it - same thing - Slicer hung at 90%.  Uninstalled the Slicer and re-installed version 2.7.3.  Went through all the above steps, and everything turned out great.
My System:
OS Name Microsoft Windows 10 Pro
Version 10.0.19045 Build 19045
Processor AMD FX(tm)-4300 Quad-Core Processor, 3800 Mhz, 2 Core(s), 4 Logical Processor(s)
Installed Physical Memory (RAM) 16.0 GB
Hard drive where Slicer is installed is a 150 GB drive with 60 GB of free space
This topic was modified 2 years temu by Halde
Opublikowany : 20/05/2024 11:10 pm
vhubbard
(@vhubbard)
RE: Prusa Slicer 2.74 Windows issues
If you want to turn in a bug, https://github.com/prusa3d   is the place to do it.  It isn't very friendly I know, but you can figure it out.  You will need a Github login.   They do look at the submissions and have asked for more details as needed.   The more that turn in reports on Github, the better the code will be.
Opublikowany : 22/05/2024 2:36 pm
Halde
(@halde)
I can do that.  I do have a Github login.  I was putting this here more for information.  I just won't use the latest version as it doesn't work for me.  🙂
Opublikowany : 22/05/2024 2:52 pm
