Prusa Slicer 2.3.2 Error
Lars
 Lars
(@lars-3)
the latest Prusa Slicer 2.3.2 runs in Errors when slicing.
I have an 64 bit Windows 10 with 32GB RAM.
First the Installer installs the 32bit Version of the Slicer not the 64bit Version
I run the installer several times, (prusa3d_win_2_3_2.exe) but nothing chages.
There is only the 32bit version and the Error remains.
Round about 10 from my 32GB RAM are used
I switched back to the 2.3.1 version. The I have the 64bit Silicer an no Error.
Because I havent a github user I will post the Error here
Regards
Prus Mini +
Posted : 09/07/2021 1:59 pm
AlastorsNight
(@alastorsnight)
RE: Prusa Slicer 2.3.2 Error
I am also having the same issues with 2.3.2, I updated from 2.3.0 because it was giving me some issues but, I have the exact same problems happening. I can only install the 32bit version and if I try to load up certain projects the program gives me the same error and then will just crash. I have 32GB of ram as well so, I know I am not running out of memory.
Posted : 09/07/2021 2:50 pm
Just grab the 64 bit version off github.  Don't even need to install, just run the .exe file from the download folder.  I never grab off the main site any more.  https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.3.2
Prusa have probably packaged up the wrong version by mistake into the installer.
btw most of the program crashes are usually down to graphics card drivers rather than memory.
Posted : 09/07/2021 3:09 pm
I downloaded the standalone installer, and it installed without any glitch on my Windows 10 system (64-bit).
Posted : 09/07/2021 4:39 pm
Ringarn67
(@ringarn67)
@fuchsr
Same here, downloaded and installed without problem on my Win 10 64-bit machine
And, it IS the 32bit version!?
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Posted : 09/07/2021 6:30 pm
Lars
 Lars
(@lars-3)
@fuchsr
Which installer did you load?
I took the prusa3d_win_2_3_2.exe ~429MB
I downloaded it twice today at 00:30 an 14:59 local time. (Europe)
Did you downloaded the installer later?
Maybe it is fixed.
This post was modified 3 years ago by Lars
Prus Mini +
Posted : 09/07/2021 6:59 pm
Ringarn67
(@ringarn67)
UPDATE:
The installer on this page https://www.prusa3d.com/drivers/ have the 32-bit version
This page https://www.prusa3d.com/prusaslicer/ have the 64-bit version
Edit: I have tested the Win installer
Posted : 09/07/2021 8:08 pm
Lars liked
Ringarn67
(@ringarn67)
Update 2:
I have run the FULL installer and the STANDALONE installer a couple of times.
The standalone one install 64-bit version and the full installer install 32-bit version
I have talked to live chat and he (Ivan) will talk to the developers.
Is there any difference in performance between PS 32-bit and PS 64-bit?
Posted : 09/07/2021 9:22 pm
Lars
 Lars
(@lars-3)
@ringarn67
Hi
thanks. I took the installer from https://www.prusa3d.com/prusaslicer/   and it seems the problem is solved.
I had sliced the file that made the prblems on the 32bit version on this 64bit version without any problems
Prus Mini +
Posted : 10/07/2021 1:21 pm
Ringarn67
(@ringarn67)
Quote from Prusa Support
"Following up with our previous chat in regards to the Full installer versions not being available for 64 bits.
There was a bad version uploaded to the server. However, it has been fixed.
Please re-download the installer and reinstall the PrusaSlicer."
I downloaded the full installer and it is 64-bit version 👍
Posted : 12/07/2021 8:18 pm
Lars liked
