Prusa slcr 2.9.0 continuos crash MacBook Pro M1
Antonio
(@antonio-2)
Hi all,
I'm trying to setup a multi-print in slicer with 10 "cylinders" with 3 numbers each, like a cylinder with 3 numbers 1, a cylinder with 3 numbers 2 etc., I've had several crashes while working with this print, I've spent some time on it because I modeled 1 cylinder, then added some text, copied and pasted 10 times, then changed the remaining 9 cylinders with increasing numbers, every time I do some work I have to save because after a while I get a random crash.
Macbook pro ram 8gb 512gb hd (half free) M1 sequoia 15.2
already reinstalled PS, still crashes
Do my Mac become old to handle that 🙁 ? (the cilinder is simple, it's like a clip with 3 numbers on it to stick on a tube H5cm L4cm each x10)
any advice?
Opublikowany : 07/01/2025 4:25 pm
Is this embossing/debossing or a colour change?  Either way it would probably be easier in CAD.  A picture might help us understand what you are trying to do.
Opublikowany : 07/01/2025 6:36 pm
Antonio
(@antonio-2)
RISPONDI: Prusa slcr 2.9.0 continuos crash MacBook Pro M1
Hi Diem,
thanks for your answer, it's a color change
here is the error log (if u can understand something, I don't):
Translated Report (Full Report Below)
Process:               PrusaSlicer [3775]
Path:                  /private/var/folders/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicer
Identifier:            com.prusa3d.slic3r/
Version:               PrusaSlicer PrusaSlicer-2.9.0 (PrusaSlicer-2.9.0)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2025-01-08 14:34:21.2572 +0100
OS Version:            macOS 15.2 (24C101)
Report Version:        12
Anonymous UUID:        5165FCFB-F45C-F207-BA7B-234A62797A9A
Sleep/Wake UUID:       185E9E36-1067-46A5-AFEF-6C0F30543FEC
Time Awake Since Boot: 12000 seconds
Time Since Wake:       158 seconds
System Integrity Protection: enabled
Crashed Thread:        4
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x000000016f900000
Exception Codes:       0x0000000000000002, 0x000000016f900000
Termination Reason:    Namespace SIGNAL, Code 10 Bus error: 10
Terminating Process:   exc handler [3775]
VM Region Info: 0x16f900000 is in 0x16f900000-0x16f904000;  bytes after start: 0  bytes before end: 16383
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      Stack                       16f4f8000-16f900000    [ 4128K] rw-/rwx SM=PRV  thread 4
--->  STACK GUARD                 16f900000-16f904000    [   16K] ---/rwx SM=NUL  stack guard for thread 5
      Stack                       16f904000-16f98c000    [  544K] rw-/rwx SM=PRV  thread 5
Thread 0:: slic3r_main Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	       0x1880faf54 mach_msg2_trap + 8
1   libsystem_kernel.dylib        	       0x18810d604 mach_msg2_internal + 80
2   libsystem_kernel.dylib        	       0x188103af8 mach_msg_overwrite + 480
3   libsystem_kernel.dylib        	       0x1880fb29c mach_msg + 24
4   CoreFoundation                	       0x188224a3c __CFRunLoopServiceMachPort + 160
5   CoreFoundation                	       0x18822329c __CFRunLoopRun + 1212
6   CoreFoundation                	       0x188222724 CFRunLoopRunSpecific + 588
7   HIToolbox                     	       0x19377a530 RunCurrentEventLoopInMode + 292
8   HIToolbox                     	       0x193780348 ReceiveNextEventCommon + 676
9   HIToolbox                     	       0x193780508 _BlockUntilNextEventMatchingListInModeWithFilter + 76
10  AppKit                        	       0x18bd8d034 _DPSNextEvent + 660
11  AppKit                        	       0x18c6f12d4 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688
12  AppKit                        	       0x18bd80060 -[NSApplication run] + 480
13  PrusaSlicer                   	       0x1035c4d30 wxGUIEventLoop::OSXDoRun() + 140
14  PrusaSlicer                   	       0x1036c8928 wxCFEventLoop::DoRun() + 40
15  PrusaSlicer                   	       0x10362d2c0 wxEventLoopBase::Run() + 192
16  PrusaSlicer                   	       0x1035fd358 wxAppConsoleBase::MainLoop() + 208
17  PrusaSlicer                   	       0x103584af4 wxApp::OnRun() + 36
18  PrusaSlicer                   	       0x103663afc wxEntry(int&, wchar_t**) + 88
19  PrusaSlicer                   	       0x101899944 Slic3r::GUI::GUI_Run(Slic3r::GUI::GUI_InitParams&) + 284
20  PrusaSlicer                   	       0x100cf0488 Slic3r::CLI::run(int, char**) + 22336
21  PrusaSlicer                   	       0x100cf5fd0 main + 220
22  dyld                          	       0x187dbc274 start + 2840
Thread 1:: com.apple.NSEventThread
7   AppKit                        	       0x18beb1a20 _NSEventThread + 148
8   libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
9   libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 2:
0   libsystem_pthread.dylib       	       0x1881370e8 start_wqthread + 0
Thread 3:
0   libsystem_kernel.dylib        	       0x1880fe6ec __psynch_cvwait + 8
1   libsystem_pthread.dylib       	       0x18813c894 _pthread_cond_wait + 1204
2   libc++.1.dylib                	       0x18807260c std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>>>) + 100
3   PrusaSlicer                   	       0x1016d2aa4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, Slic3r::GUI::UserAccountCommunication::init_session_thread()::$_0>>(void*) + 188
4   libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
5   libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 4 Crashed:
0   PrusaSlicer                   	       0x101f6efc4 __gmpn_sub_n + 124
1   PrusaSlicer                   	       0x101f6d730 __gmpz_sub + 788
2   ???                           	0xffffa000ed8509c3 ???
Thread 5:
7   CoreFoundation                	       0x18829d9d0 CFRunLoopRun + 64
8   3DconnexionClient             	       0x115db6d0c -[ConnexionClientAPI clientThreadEntry] + 224
9   Foundation                    	       0x1893ecc24 __NSThread__start__ + 724
10  libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
11  libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 6:
Thread 7:
0   libsystem_kernel.dylib        	       0x1880faed0 semaphore_wait_trap + 8
1   PrusaSlicer                   	       0x10229fbe8 tbb::detail::r1::rml::private_worker::run() + 412
2   PrusaSlicer                   	       0x10229fa40 tbb::detail::r1::rml::private_worker::thread_routine(void*) + 12
3   libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
4   libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 4 crashed with ARM Thread State (64-bit):
    x0: 0x000000016f8fffa0   x1: 0x000000016f8fffa0   x2: 0x000000016f8ffff0   x3: 0x0000000000000004
    x4: 0x0000000000000000   x5: 0x0000000000000000   x6: 0x0000000000000000   x7: 0x0000000000000000
    x8: 0x0000000000000000   x9: 0x0000000000000000  x10: 0x0000000000000000  x11: 0x0000000000000000
   x12: 0x0000000000000000  x13: 0x0000000000000000  x14: 0xe000000000000000  x15: 0x0000000000000010
   x16: 0x000000016f8f8ee0  x17: 0x00000000000002af  x18: 0xfffffffffffffe03  x19: 0x000000016f8f8f38
   x20: 0x0000000000000004  x21: 0x000000016f8f8eb0  x22: 0x000000016f8f8f00  x23: 0x0000000000000004
   x24: 0x0000000000000004  x25: 0xfffffffffffffffc  x26: 0x000000016f8f8f38  x27: 0x0000000000000002
   x28: 0x0000000000000002   fp: 0x000000016f8f8fd0   lr: 0x0000000101f6d730
    sp: 0x000000016f8f8e60   pc: 0x0000000101f6efc4 cpsr: 0x60001000
   far: 0x000000016f900000  esr: 0x92000007 (Data Abort) byte read Translation fault
Binary Images:
       0x100ce0000 -        0x103fcbfff com.prusa3d.slic3r/ (PrusaSlicer PrusaSlicer-2.9.0) <2398bcea-e91a-3632-a8d2-367669fbca4c> /private/var/folders/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicer
       0x105be8000 -        0x105c93fff libzstd.1.5.6.dylib (*) <50bb16ab-207a-38ca-9641-7ea02ee57990> /private/var/folders/*/PrusaSlicer.app/Contents/Frameworks/libzstd.1.5.6.dylib
       0x111cc4000 -        0x111ccffff libobjc-trampolines.dylib (*) <fcf9b985-2748-371b-98d3-37a06a9bf107> /usr/lib/libobjc-trampolines.dylib
       0x11360c000 -        0x113caffff com.apple.AGXMetal13-3 (323.15) <0253a4e5-17e3-37f5-acf3-f698f08fa3a9> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3
       0x1157f0000 -        0x115857fff com.apple.AppleMetalOpenGLRenderer (1.0) <d066b74f-d423-38de-9a8d-16b1bcddb1c7> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
       0x115dac000 -        0x115dbbfff com.3dconnexion.driver.client (1.3.3) <10a99a6c-2c58-3b9d-a2a6-f204869a06f5> /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
       0x15143c000 -        0x15145bfff com.apple.security.csparser (3.0) <2a2de3cc-2e01-35ae-8386-e51c0bb4070f> /System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x1880fa000 -        0x188134ff7 libsystem_kernel.dylib (*) <dfc9530c-e75b-3d1c-a9a6-85c8a709d6a7> /usr/lib/system/libsystem_kernel.dylib
       0x1881a7000 -        0x18869bfff com.apple.CoreFoundation (6.9) <41fdd393-3acc-328d-8108-e59a3a947ec5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x19366f000 -        0x193976fff com.apple.HIToolbox (2.1.1) <83159ee1-0ca4-3a91-887a-db80b7029337> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
       0x18bd52000 -        0x18d18afff com.apple.AppKit (6.9) <4251ee1c-062c-3b9a-b6e2-751f77ef9f4a> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x187db6000 -        0x187e37f3f dyld (*) <4ce86d18-f3fa-3d2a-a1b8-e7cd8a52fb0d> /usr/lib/dyld
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x188135000 -        0x188141fff libsystem_pthread.dylib (*) <f1661613-b1c8-320d-b69d-97f174130e29> /usr/lib/system/libsystem_pthread.dylib
       0x188051000 -        0x1880deffb libc++.1.dylib (*) <fe5f2fbb-d3b5-30bc-bad8-3571ac2a72a0> /usr/lib/libc++.1.dylib
       0x189398000 -        0x18a1e0fff com.apple.Foundation (6.9) <b39c1e42-f15f-3671-b63e-6be7bdad0fcd> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)
Writable regions: Total=2.9G written=1574K(0%) resident=1574K(0%) swapped_out=0K(0%) unallocated=2.9G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               256K        2
Activity Tracing                   256K        1
CG image                          11.8M      224
CG raster data                     272K        1
ColorSync                          768K       38
CoreAnimation                     2720K       92
CoreGraphics                        48K        3
CoreUI image data                 2576K       20
Foundation                          48K        2
Kernel Alloc Once                   32K        1
MALLOC                             2.8G       81
MALLOC guard page                  288K       18
OpenGL GLSL                        256K        3
STACK GUARD                       56.3M       20
Stack                             46.1M       22
VM_ALLOCATE                       24.5M      130
__AUTH                            5203K      668
__AUTH_CONST                      69.8M      910
__CTF                               824        1
__DATA                            25.4M      892
__DATA_CONST                      25.4M      922
__DATA_DIRTY                      2757K      337
__FONT_DATA                        2352        1
__GLSLBUILTINS                    5174K        1
__INFO_FILTER                         8        1
__LINKEDIT                       632.7M        8
__OBJC_RW                         2373K        1
__TEXT                             1.0G      945
__TPRO_CONST                       272K        2
dyld private memory                 48K        2
mapped file                      268.5M       35
owned unmapped memory             15.1M        1
page table in kernel              1574K        1
shared memory                      912K       15
TOTAL                              5.0G     5401
Full Report
{"app_name":"PrusaSlicer","timestamp":"2025-01-08 14:34:24.00 +0100","app_version":"PrusaSlicer PrusaSlicer-2.9.0","slice_uuid":"2398bcea-e91a-3632-a8d2-367669fbca4c","build_version":"PrusaSlicer-2.9.0","platform":1,"bundleID":"com.prusa3d.slic3r\/","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.2 (24C101)","roots_installed":0,"name":"PrusaSlicer","incident_id":"080B390F-5B38-4AF2-BCCA-F305506EEFF6"}
  "uptime" : 12000,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro17,1",
  "coalitionID" : 3079,
  "osVersion" : {
    "train" : "macOS 15.2",
    "build" : "24C101",
    "releaseType" : "User"
  "captureTime" : "2025-01-08 14:34:21.2572 +0100",
  "codeSigningMonitor" : 1,
  "incident" : "080B390F-5B38-4AF2-BCCA-F305506EEFF6",
  "pid" : 3775,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2025-01-08 14:31:55.6221 +0100",
  "procStartAbsTime" : 294761894600,
  "procExitAbsTime" : 298256302148,
  "procName" : "PrusaSlicer",
  "procPath" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/MacOS\/PrusaSlicer",
  "bundleInfo" : {"CFBundleShortVersionString":"PrusaSlicer PrusaSlicer-2.9.0","CFBundleVersion":"PrusaSlicer-2.9.0","CFBundleIdentifier":"com.prusa3d.slic3r\/"},
  "storeInfo" : {"deviceIdentifierForVendor":"35E4EE98-F476-58EF-ABC0-E3D890D17DBE","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.prusa3d.slic3r\/",
  "crashReporterKey" : "5165FCFB-F45C-F207-BA7B-234A62797A9A",
  "codeSigningID" : "com.prusa3d.slic3r\/",
  "codeSigningTeamID" : "DKPB65N43Z",
  "codeSigningFlags" : 570495745,
  "codeSigningValidationCategory" : 6,
  "codeSigningTrustLevel" : 4294967295,
  "instructionByteStream" : {"beforePC":"JBRAqUgkQKkhQADRQkAA0QoAABQmHECpSixAqdIBALQfIAPVJBRBqQ==","atPC":"SCRBqcwACvrtAAv6DDSBqCYcwqlKLMKpjAAI+q0ACfoMNIGoUgYA0Q=="},
  "bootSessionUUID" : "0D6A2DBC-CA90-48DA-9079-F97A43709A03",
  "wakeTime" : 158,
  "sleepWakeUUID" : "185E9E36-1067-46A5-AFEF-6C0F30543FEC",
  "sip" : "enabled",
  "vmRegionInfo" : "0x16f900000 is in 0x16f900000-0x16f904000;  bytes after start: 0  bytes before end: 16383\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      Stack                       16f4f8000-16f900000    [ 4128K] rw-\/rwx SM=PRV  thread 4\n--->  STACK GUARD                 16f900000-16f904000    [   16K] ---\/rwx SM=NUL  stack guard for thread 5\n      Stack                       16f904000-16f98c000    [  544K] rw-\/rwx SM=PRV  thread 5",
  "exception" : {"codes":"0x0000000000000002, 0x000000016f900000","rawCodes":[2,6166675456],"type":"EXC_BAD_ACCESS","signal":"SIGBUS","subtype":"KERN_PROTECTION_FAILURE at 0x000000016f900000"},
  "termination" : {"flags":0,"code":10,"namespace":"SIGNAL","indicator":"Bus error: 10","byProc":"exc handler","byPid":3775},
  "vmregioninfo" : "0x16f900000 is in 0x16f900000-0x16f904000;  bytes after start: 0  bytes before end: 16383\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      Stack                       16f4f8000-16f900000    [ 4128K] rw-\/rwx SM=PRV  thread 4\n--->  STACK GUARD                 16f900000-16f904000    [   16K] ---\/rwx SM=NUL  stack guard for thread 5\n      Stack                       16f904000-16f98c000    [  544K] rw-\/rwx SM=PRV  thread 5",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 4,
  "threads" : [{"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":27500675596288},{"value":0},{"value":27500675596288},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":6403},{"value":18944},{"value":0},{"value":18446744073709551569},{"value":8489576424},{"value":0},{"value":4294967295},{"value":2},{"value":27500675596288},{"value":0},{"value":27500675596288},{"value":6158387064},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577772036},"cpsr":{"value":4096},"fp":{"value":6158386912},"sp":{"value":6158386832},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696596},"far":{"value":0}},"id":203985,"name":"slic3r_main","queue":"com.apple.main-thread","frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":7},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":7},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":7},{"imageOffset":514620,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":508572,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":8},{"imageOffset":505636,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":8},{"imageOffset":1094960,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":9},{"imageOffset":1119048,"symbol":"ReceiveNextEventCommon","symbolLocation":676,"imageIndex":9},{"imageOffset":1119496,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":9},{"imageOffset":241716,"symbol":"_DPSNextEvent","symbolLocation":660,"imageIndex":10},{"imageOffset":10089172,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":688,"imageIndex":10},{"imageOffset":188512,"symbol":"-[NSApplication run]","symbolLocation":480,"imageIndex":10},{"imageOffset":42880304,"symbol":"wxGUIEventLoop::OSXDoRun()","symbolLocation":140,"imageIndex":0},{"imageOffset":43944232,"symbol":"wxCFEventLoop::DoRun()","symbolLocation":40,"imageIndex":0},{"imageOffset":43307712,"symbol":"wxEventLoopBase::Run()","symbolLocation":192,"imageIndex":0},{"imageOffset":43111256,"symbol":"wxAppConsoleBase::MainLoop()","symbolLocation":208,"imageIndex":0},{"imageOffset":42617588,"symbol":"wxApp::OnRun()","symbolLocation":36,"imageIndex":0},{"imageOffset":43531004,"symbol":"wxEntry(int&, wchar_t**)","symbolLocation":88,"imageIndex":0},{"imageOffset":12294468,"symbol":"Slic3r::GUI::GUI_Run(Slic3r::GUI::GUI_InitParams&)","symbolLocation":284,"imageIndex":0},{"imageOffset":66696,"symbol":"Slic3r::CLI::run(int, char**)","symbolLocation":22336,"imageIndex":0},{"imageOffset":90064,"symbol":"main","symbolLocation":220,"imageIndex":0},{"imageOffset":25204,"symbol":"start","symbolLocation":2840,"imageIndex":11}]},{"id":204039,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":163857297309696},{"value":0},{"value":163857297309696},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":38151},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8489576424},{"value":0},{"value":4294967295},{"value":2},{"value":163857297309696},{"value":0},{"value":163857297309696},{"value":6160687208},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577772036},"cpsr":{"value":4096},"fp":{"value":6160687056},"sp":{"value":6160686976},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696596},"far":{"value":0}},"frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":7},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":7},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":7},{"imageOffset":514620,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":508572,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":8},{"imageOffset":505636,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":8},{"imageOffset":1440288,"symbol":"_NSEventThread","symbolLocation":148,"imageIndex":10},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}]},{"id":204047,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6161264640},{"value":48143},{"value":6160728064},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6161264640},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":204064,"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":7},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":13},{"imageOffset":136716,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>>>)","symbolLocation":100,"imageIndex":14},{"imageOffset":10431140,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, Slic3r::GUI::UserAccountCommunication::init_session_thread()::$_0>>(void*)","symbolLocation":188,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":260},{"value":0},{"value":4096},{"value":0},{"value":0},{"value":160},{"value":88887},{"value":999998834},{"value":6162411176},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8489593960},{"value":0},{"value":4638336216},{"value":4638336280},{"value":6162411744},{"value":999998834},{"value":88887},{"value":4096},{"value":4097},{"value":4352},{"value":18437520701672696841},{"value":171841360874625}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577965204},"cpsr":{"value":1610616832},"fp":{"value":6162411296},"sp":{"value":6162411152},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577710828},"far":{"value":0}}},{"triggered":true,"id":204065,"threadState":{"x":[{"value":6166675360},{"value":6166675360},{"value":6166675440},{"value":4},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":16140901064495857664},{"value":16},{"value":6166646496},{"value":687},{"value":18446744073709551107},{"value":6166646584},{"value":4},{"value":6166646448},{"value":6166646528},{"value":4},{"value":4},{"value":18446744073709551612},{"value":6166646584},{"value":2},{"value":2}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4327921456},"cpsr":{"value":1610616832},"fp":{"value":6166646736},"sp":{"value":6166646368},"esr":{"value":2449473543,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4327927748,"matchesCrashFrame":1},"far":{"value":6166675456}},"frames":[{"imageOffset":19460036,"symbol":"__gmpn_sub_n","symbolLocation":124,"imageIndex":0},{"imageOffset":19453744,"symbol":"__gmpz_sub","symbolLocation":788,"imageIndex":0},{"imageOffset":18446638524578204099,"imageIndex":12}]},{"id":204068,"frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":7},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":7},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":7},{"imageOffset":514620,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":508572,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":8},{"imageOffset":505636,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":8},{"imageOffset":1010128,"symbol":"CFRunLoopRun","symbolLocation":64,"imageIndex":8},{"imageOffset":44300,"symbol":"-[ConnexionClientAPI clientThreadEntry]","symbolLocation":224,"imageIndex":5},{"imageOffset":347172,"symbol":"__NSThread__start__","symbolLocation":724,"imageIndex":15},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":349657582534656},{"value":0},{"value":349657582534656},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":81411},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8489576424},{"value":0},{"value":4294967295},{"value":2},{"value":349657582534656},{"value":0},{"value":349657582534656},{"value":6167223608},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577772036},"cpsr":{"value":4096},"fp":{"value":6167223456},"sp":{"value":6167223376},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696596},"far":{"value":0}}},{"id":204080,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6171815936},{"value":130563},{"value":6171279360},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6171815936},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":204549,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169383552},{"value":0},{"value":1},{"value":0},{"value":82},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":3590549505},{"value":3588450306},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081664},{"value":4615707264},{"value":1},{"value":82},{"value":4978081704},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6254915504},"sp":{"value":6254915456},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204550,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553168851648},{"value":0},{"value":1},{"value":1},{"value":80},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":3387009086},{"value":3384909887},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081792},{"value":4864465408},{"value":1},{"value":80},{"value":4978081832},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6259158960},"sp":{"value":6259158912},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204551,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169383808},{"value":0},{"value":1},{"value":0},{"value":81},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":3594749947},{"value":3592648708},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081408},{"value":4863390976},{"value":1},{"value":81},{"value":4978081448},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6263402416},"sp":{"value":6263402368},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204552,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553170724608},{"value":0},{"value":1},{"value":1},{"value":80},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":2845857890},{"value":2843758695},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081152},{"value":4864632960},{"value":1},{"value":80},{"value":4978081192},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6267645872},"sp":{"value":6267645824},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204553,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169399936},{"value":0},{"value":1},{"value":0},{"value":83},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":4286810107},{"value":4284708866},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081536},{"value":4615401344},{"value":1},{"value":83},{"value":4978081576},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6271889328},"sp":{"value":6271889280},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204554,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169448384},{"value":0},{"value":1},{"value":1},{"value":81},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":2977962094},{"value":2975862895},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081280},{"value":4665453184},{"value":1},{"value":81},{"value":4978081320},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6276132784},"sp":{"value":6276132736},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204555,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169451520},{"value":0},{"value":1},{"value":0},{"value":81},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":2642608146},{"value":2640508942},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081024},{"value":4864473216},{"value":1},{"value":81},{"value":4978081064},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6280376240},"sp":{"value":6280376192},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204557,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6160117760},{"value":174595},{"value":6159581184},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6160117760},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":204701,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6158970880},{"value":179979},{"value":6158434304},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6158970880},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":206997,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6161838080},{"value":260855},{"value":6161301504},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6161838080},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":207154,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6159544320},{"value":260203},{"value":6159007744},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6159544320},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":207155,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6168375296},{"value":130851},{"value":6167838720},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6168375296},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":207266,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6168948736},{"value":261691},{"value":6168412160},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6168948736},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4308467712,
    "CFBundleShortVersionString" : "PrusaSlicer PrusaSlicer-2.9.0",
    "CFBundleIdentifier" : "com.prusa3d.slic3r\/",
    "size" : 53395456,
    "uuid" : "2398bcea-e91a-3632-a8d2-367669fbca4c",
    "path" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/MacOS\/PrusaSlicer",
    "name" : "PrusaSlicer",
    "CFBundleVersion" : "PrusaSlicer-2.9.0"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4391337984,
    "size" : 704512,
    "uuid" : "50bb16ab-207a-38ca-9641-7ea02ee57990",
    "path" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/Frameworks\/libzstd.1.5.6.dylib",
    "name" : "libzstd.1.5.6.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4593565696,
    "size" : 49152,
    "uuid" : "fcf9b985-2748-371b-98d3-37a06a9bf107",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4620075008,
    "CFBundleShortVersionString" : "323.15",
    "CFBundleIdentifier" : "com.apple.AGXMetal13-3",
    "size" : 6963200,
    "uuid" : "0253a4e5-17e3-37f5-acf3-f698f08fa3a9",
    "path" : "\/System\/Library\/Extensions\/AGXMetal13_3.bundle\/Contents\/MacOS\/AGXMetal13_3",
    "name" : "AGXMetal13_3",
    "CFBundleVersion" : "323.15"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4655611904,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
    "size" : 425984,
    "uuid" : "d066b74f-d423-38de-9a8d-16b1bcddb1c7",
    "path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",
    "name" : "AppleMetalOpenGLRenderer",
    "CFBundleVersion" : "1"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4661624832,
    "CFBundleShortVersionString" : "1.3.3",
    "CFBundleIdentifier" : "com.3dconnexion.driver.client",
    "size" : 65536,
    "uuid" : "10a99a6c-2c58-3b9d-a2a6-f204869a06f5",
    "path" : "\/Library\/Frameworks\/3DconnexionClient.framework\/Versions\/A\/3DconnexionClient",
    "name" : "3DconnexionClient",
    "CFBundleVersion" : "1.3.3.446"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 5658361856,
    "CFBundleShortVersionString" : "3.0",
    "CFBundleIdentifier" : "com.apple.security.csparser",
    "size" : 131072,
    "uuid" : "2a2de3cc-2e01-35ae-8386-e51c0bb4070f",
    "path" : "\/System\/Library\/Frameworks\/Security.framework\/Versions\/A\/PlugIns\/csparser.bundle\/Contents\/MacOS\/csparser",
    "name" : "csparser",
    "CFBundleVersion" : "61439.60.117"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577692672,
    "size" : 241656,
    "uuid" : "dfc9530c-e75b-3d1c-a9a6-85c8a709d6a7",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6578401280,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5197824,
    "uuid" : "41fdd393-3acc-328d-8108-e59a3a947ec5",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "3208"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6767964160,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3178496,
    "uuid" : "83159ee1-0ca4-3a91-887a-db80b7029337",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6640967680,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 21204992,
    "uuid" : "4251ee1c-062c-3b9a-b6e2-751f77ef9f4a",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2575.30.19"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6574268416,
    "size" : 532288,
    "uuid" : "4ce86d18-f3fa-3d2a-a1b8-e7cd8a52fb0d",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577934336,
    "size" : 53248,
    "uuid" : "f1661613-b1c8-320d-b69d-97f174130e29",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577000448,
    "size" : 581628,
    "uuid" : "fe5f2fbb-d3b5-30bc-bad8-3571ac2a72a0",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6597214208,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 14979072,
    "uuid" : "b39c1e42-f15f-3671-b63e-6be7bdad0fcd",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
  "sharedCache" : {
  "base" : 6573457408,
  "size" : 4861722624,
  "uuid" : "e36100c7-89e7-3970-8938-8483ccd7019a"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)\nWritable regions: Total=2.9G written=1574K(0%) resident=1574K(0%) swapped_out=0K(0%) unallocated=2.9G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               256K        2 \nActivity Tracing                   256K        1 \nCG image                          11.8M      224 \nCG raster data                     272K        1 \nColorSync                          768K       38 \nCoreAnimation                     2720K       92 \nCoreGraphics                        48K        3 \nCoreUI image data                 2576K       20 \nFoundation                          48K        2 \nKernel Alloc Once                   32K        1 \nMALLOC                             2.8G       81 \nMALLOC guard page                  288K       18 \nOpenGL GLSL                        256K        3 \nSTACK GUARD                       56.3M       20 \nStack                             46.1M       22 \nVM_ALLOCATE                       24.5M      130 \n__AUTH                            5203K      668 \n__AUTH_CONST                      69.8M      910 \n__CTF                               824        1 \n__DATA                            25.4M      892 \n__DATA_CONST                      25.4M      922 \n__DATA_DIRTY                      2757K      337 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__INFO_FILTER                         8        1 \n__LINKEDIT                       632.7M        8 \n__OBJC_RW                         2373K        1 \n__TEXT                             1.0G      945 \n__TPRO_CONST                       272K        2 \ndyld private memory                 48K        2 \nmapped file                      268.5M       35 \nowned unmapped memory             15.1M        1 \npage table in kernel              1574K        1 \nshared memory                      912K       15 \n===========                     =======  ======= \nTOTAL                              5.0G     5401 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "logWritingSignature" : "3da12ee2de9ce51c3d4666e88534a4c277e79ee6",
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "64c17a9925d75a7281053d4c",
      "factorPackIds" : {
        "SIRI_AUDIO_DISABLE_MEDIA_ENTITY_SYNC" : "64d29746ad29a465b3bbeace"
      "deploymentId" : 240000002
      "rolloutId" : "63f9578e238e7b23a1f3030a",
      "factorPackIds" : {
      "deploymentId" : 240000005
  "experiments" : [
Model: MacBookPro17,1, BootROM 11881.61.3, proc 8:4:4 processors, 8 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Memory Module: LPDDR4, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Sep 28 2024 04:40:32 version 18.20.462.0.7.8.175 FWID 01-10fa77df
IO80211_driverkit-1345.8 "IO80211_driverkit-1345.8" Nov  9 2024 17:02:32
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
Opublikowany : 08/01/2025 1:58 pm
