Prusa slcr 2.9.0 continuos crash MacBook Pro M1
Antonio
(@antonio-2)
Hi all,
I'm trying to setup a multi-print in slicer with 10 "cylinders" with 3 numbers each, like a cylinder with 3 numbers 1, a cylinder with 3 numbers 2 etc., I've had several crashes while working with this print, I've spent some time on it because I modeled 1 cylinder, then added some text, copied and pasted 10 times, then changed the remaining 9 cylinders with increasing numbers, every time I do some work I have to save because after a while I get a random crash.
Macbook pro ram 8gb 512gb hd (half free) M1 sequoia 15.2
already reinstalled PS, still crashes
Do my Mac become old to handle that 🙁 ? (the cilinder is simple, it's like a clip with 3 numbers on it to stick on a tube H5cm L4cm each x10)
any advice?
Veröffentlicht : 07/01/2025 4:25 pm
Is this embossing/debossing or a colour change?  Either way it would probably be easier in CAD.  A picture might help us understand what you are trying to do.
Veröffentlicht : 07/01/2025 6:36 pm
Antonio
(@antonio-2)
RISPONDI: Prusa slcr 2.9.0 continuos crash MacBook Pro M1
Hi Diem,
thanks for your answer, it's a color change
here is the error log (if u can understand something, I don't):
Translated Report (Full Report Below)
Process:               PrusaSlicer [3775]
Path:                  /private/var/folders/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicer
Identifier:            com.prusa3d.slic3r/
Version:               PrusaSlicer PrusaSlicer-2.9.0 (PrusaSlicer-2.9.0)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2025-01-08 14:34:21.2572 +0100
OS Version:            macOS 15.2 (24C101)
Report Version:        12
Anonymous UUID:        5165FCFB-F45C-F207-BA7B-234A62797A9A
Sleep/Wake UUID:       185E9E36-1067-46A5-AFEF-6C0F30543FEC
Time Awake Since Boot: 12000 seconds
Time Since Wake:       158 seconds
System Integrity Protection: enabled
Crashed Thread:        4
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x000000016f900000
Exception Codes:       0x0000000000000002, 0x000000016f900000
Termination Reason:    Namespace SIGNAL, Code 10 Bus error: 10
Terminating Process:   exc handler [3775]
VM Region Info: 0x16f900000 is in 0x16f900000-0x16f904000;  bytes after start: 0  bytes before end: 16383
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      Stack                       16f4f8000-16f900000    [ 4128K] rw-/rwx SM=PRV  thread 4
--->  STACK GUARD                 16f900000-16f904000    [   16K] ---/rwx SM=NUL  stack guard for thread 5
      Stack                       16f904000-16f98c000    [  544K] rw-/rwx SM=PRV  thread 5
Thread 0:: slic3r_main Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	       0x1880faf54 mach_msg2_trap + 8
1   libsystem_kernel.dylib        	       0x18810d604 mach_msg2_internal + 80
2   libsystem_kernel.dylib        	       0x188103af8 mach_msg_overwrite + 480
3   libsystem_kernel.dylib        	       0x1880fb29c mach_msg + 24
4   CoreFoundation                	       0x188224a3c __CFRunLoopServiceMachPort + 160
5   CoreFoundation                	       0x18822329c __CFRunLoopRun + 1212
6   CoreFoundation                	       0x188222724 CFRunLoopRunSpecific + 588
7   HIToolbox                     	       0x19377a530 RunCurrentEventLoopInMode + 292
8   HIToolbox                     	       0x193780348 ReceiveNextEventCommon + 676
9   HIToolbox                     	       0x193780508 _BlockUntilNextEventMatchingListInModeWithFilter + 76
10  AppKit                        	       0x18bd8d034 _DPSNextEvent + 660
11  AppKit                        	       0x18c6f12d4 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688
12  AppKit                        	       0x18bd80060 -[NSApplication run] + 480
13  PrusaSlicer                   	       0x1035c4d30 wxGUIEventLoop::OSXDoRun() + 140
14  PrusaSlicer                   	       0x1036c8928 wxCFEventLoop::DoRun() + 40
15  PrusaSlicer                   	       0x10362d2c0 wxEventLoopBase::Run() + 192
16  PrusaSlicer                   	       0x1035fd358 wxAppConsoleBase::MainLoop() + 208
17  PrusaSlicer                   	       0x103584af4 wxApp::OnRun() + 36
18  PrusaSlicer                   	       0x103663afc wxEntry(int&, wchar_t**) + 88
19  PrusaSlicer                   	       0x101899944 Slic3r::GUI::GUI_Run(Slic3r::GUI::GUI_InitParams&) + 284
20  PrusaSlicer                   	       0x100cf0488 Slic3r::CLI::run(int, char**) + 22336
21  PrusaSlicer                   	       0x100cf5fd0 main + 220
22  dyld                          	       0x187dbc274 start + 2840
Thread 1:: com.apple.NSEventThread
7   AppKit                        	       0x18beb1a20 _NSEventThread + 148
8   libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
9   libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 2:
0   libsystem_pthread.dylib       	       0x1881370e8 start_wqthread + 0
Thread 3:
0   libsystem_kernel.dylib        	       0x1880fe6ec __psynch_cvwait + 8
1   libsystem_pthread.dylib       	       0x18813c894 _pthread_cond_wait + 1204
2   libc++.1.dylib                	       0x18807260c std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>>>) + 100
3   PrusaSlicer                   	       0x1016d2aa4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, Slic3r::GUI::UserAccountCommunication::init_session_thread()::$_0>>(void*) + 188
4   libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
5   libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 4 Crashed:
0   PrusaSlicer                   	       0x101f6efc4 __gmpn_sub_n + 124
1   PrusaSlicer                   	       0x101f6d730 __gmpz_sub + 788
2   ???                           	0xffffa000ed8509c3 ???
Thread 5:
7   CoreFoundation                	       0x18829d9d0 CFRunLoopRun + 64
8   3DconnexionClient             	       0x115db6d0c -[ConnexionClientAPI clientThreadEntry] + 224
9   Foundation                    	       0x1893ecc24 __NSThread__start__ + 724
10  libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
11  libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 6:
Thread 7:
0   libsystem_kernel.dylib        	       0x1880faed0 semaphore_wait_trap + 8
1   PrusaSlicer                   	       0x10229fbe8 tbb::detail::r1::rml::private_worker::run() + 412
2   PrusaSlicer                   	       0x10229fa40 tbb::detail::r1::rml::private_worker::thread_routine(void*) + 12
3   libsystem_pthread.dylib       	       0x18813c2e4 _pthread_start + 136
4   libsystem_pthread.dylib       	       0x1881370fc thread_start + 8
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 4 crashed with ARM Thread State (64-bit):
    x0: 0x000000016f8fffa0   x1: 0x000000016f8fffa0   x2: 0x000000016f8ffff0   x3: 0x0000000000000004
    x4: 0x0000000000000000   x5: 0x0000000000000000   x6: 0x0000000000000000   x7: 0x0000000000000000
    x8: 0x0000000000000000   x9: 0x0000000000000000  x10: 0x0000000000000000  x11: 0x0000000000000000
   x12: 0x0000000000000000  x13: 0x0000000000000000  x14: 0xe000000000000000  x15: 0x0000000000000010
   x16: 0x000000016f8f8ee0  x17: 0x00000000000002af  x18: 0xfffffffffffffe03  x19: 0x000000016f8f8f38
   x20: 0x0000000000000004  x21: 0x000000016f8f8eb0  x22: 0x000000016f8f8f00  x23: 0x0000000000000004
   x24: 0x0000000000000004  x25: 0xfffffffffffffffc  x26: 0x000000016f8f8f38  x27: 0x0000000000000002
   x28: 0x0000000000000002   fp: 0x000000016f8f8fd0   lr: 0x0000000101f6d730
    sp: 0x000000016f8f8e60   pc: 0x0000000101f6efc4 cpsr: 0x60001000
   far: 0x000000016f900000  esr: 0x92000007 (Data Abort) byte read Translation fault
Binary Images:
       0x100ce0000 -        0x103fcbfff com.prusa3d.slic3r/ (PrusaSlicer PrusaSlicer-2.9.0) <2398bcea-e91a-3632-a8d2-367669fbca4c> /private/var/folders/*/PrusaSlicer.app/Contents/MacOS/PrusaSlicer
       0x105be8000 -        0x105c93fff libzstd.1.5.6.dylib (*) <50bb16ab-207a-38ca-9641-7ea02ee57990> /private/var/folders/*/PrusaSlicer.app/Contents/Frameworks/libzstd.1.5.6.dylib
       0x111cc4000 -        0x111ccffff libobjc-trampolines.dylib (*) <fcf9b985-2748-371b-98d3-37a06a9bf107> /usr/lib/libobjc-trampolines.dylib
       0x11360c000 -        0x113caffff com.apple.AGXMetal13-3 (323.15) <0253a4e5-17e3-37f5-acf3-f698f08fa3a9> /System/Library/Extensions/AGXMetal13_3.bundle/Contents/MacOS/AGXMetal13_3
       0x1157f0000 -        0x115857fff com.apple.AppleMetalOpenGLRenderer (1.0) <d066b74f-d423-38de-9a8d-16b1bcddb1c7> /System/Library/Extensions/AppleMetalOpenGLRenderer.bundle/Contents/MacOS/AppleMetalOpenGLRenderer
       0x115dac000 -        0x115dbbfff com.3dconnexion.driver.client (1.3.3) <10a99a6c-2c58-3b9d-a2a6-f204869a06f5> /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
       0x15143c000 -        0x15145bfff com.apple.security.csparser (3.0) <2a2de3cc-2e01-35ae-8386-e51c0bb4070f> /System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x1880fa000 -        0x188134ff7 libsystem_kernel.dylib (*) <dfc9530c-e75b-3d1c-a9a6-85c8a709d6a7> /usr/lib/system/libsystem_kernel.dylib
       0x1881a7000 -        0x18869bfff com.apple.CoreFoundation (6.9) <41fdd393-3acc-328d-8108-e59a3a947ec5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x19366f000 -        0x193976fff com.apple.HIToolbox (2.1.1) <83159ee1-0ca4-3a91-887a-db80b7029337> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
       0x18bd52000 -        0x18d18afff com.apple.AppKit (6.9) <4251ee1c-062c-3b9a-b6e2-751f77ef9f4a> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x187db6000 -        0x187e37f3f dyld (*) <4ce86d18-f3fa-3d2a-a1b8-e7cd8a52fb0d> /usr/lib/dyld
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x188135000 -        0x188141fff libsystem_pthread.dylib (*) <f1661613-b1c8-320d-b69d-97f174130e29> /usr/lib/system/libsystem_pthread.dylib
       0x188051000 -        0x1880deffb libc++.1.dylib (*) <fe5f2fbb-d3b5-30bc-bad8-3571ac2a72a0> /usr/lib/libc++.1.dylib
       0x189398000 -        0x18a1e0fff com.apple.Foundation (6.9) <b39c1e42-f15f-3671-b63e-6be7bdad0fcd> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)
Writable regions: Total=2.9G written=1574K(0%) resident=1574K(0%) swapped_out=0K(0%) unallocated=2.9G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               256K        2
Activity Tracing                   256K        1
CG image                          11.8M      224
CG raster data                     272K        1
ColorSync                          768K       38
CoreAnimation                     2720K       92
CoreGraphics                        48K        3
CoreUI image data                 2576K       20
Foundation                          48K        2
Kernel Alloc Once                   32K        1
MALLOC                             2.8G       81
MALLOC guard page                  288K       18
OpenGL GLSL                        256K        3
STACK GUARD                       56.3M       20
Stack                             46.1M       22
VM_ALLOCATE                       24.5M      130
__AUTH                            5203K      668
__AUTH_CONST                      69.8M      910
__CTF                               824        1
__DATA                            25.4M      892
__DATA_CONST                      25.4M      922
__DATA_DIRTY                      2757K      337
__FONT_DATA                        2352        1
__GLSLBUILTINS                    5174K        1
__INFO_FILTER                         8        1
__LINKEDIT                       632.7M        8
__OBJC_RW                         2373K        1
__TEXT                             1.0G      945
__TPRO_CONST                       272K        2
dyld private memory                 48K        2
mapped file                      268.5M       35
owned unmapped memory             15.1M        1
page table in kernel              1574K        1
shared memory                      912K       15
TOTAL                              5.0G     5401
Full Report
{"app_name":"PrusaSlicer","timestamp":"2025-01-08 14:34:24.00 +0100","app_version":"PrusaSlicer PrusaSlicer-2.9.0","slice_uuid":"2398bcea-e91a-3632-a8d2-367669fbca4c","build_version":"PrusaSlicer-2.9.0","platform":1,"bundleID":"com.prusa3d.slic3r\/","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.2 (24C101)","roots_installed":0,"name":"PrusaSlicer","incident_id":"080B390F-5B38-4AF2-BCCA-F305506EEFF6"}
  "uptime" : 12000,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro17,1",
  "coalitionID" : 3079,
  "osVersion" : {
    "train" : "macOS 15.2",
    "build" : "24C101",
    "releaseType" : "User"
  "captureTime" : "2025-01-08 14:34:21.2572 +0100",
  "codeSigningMonitor" : 1,
  "incident" : "080B390F-5B38-4AF2-BCCA-F305506EEFF6",
  "pid" : 3775,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2025-01-08 14:31:55.6221 +0100",
  "procStartAbsTime" : 294761894600,
  "procExitAbsTime" : 298256302148,
  "procName" : "PrusaSlicer",
  "procPath" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/MacOS\/PrusaSlicer",
  "bundleInfo" : {"CFBundleShortVersionString":"PrusaSlicer PrusaSlicer-2.9.0","CFBundleVersion":"PrusaSlicer-2.9.0","CFBundleIdentifier":"com.prusa3d.slic3r\/"},
  "storeInfo" : {"deviceIdentifierForVendor":"35E4EE98-F476-58EF-ABC0-E3D890D17DBE","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.prusa3d.slic3r\/",
  "crashReporterKey" : "5165FCFB-F45C-F207-BA7B-234A62797A9A",
  "codeSigningID" : "com.prusa3d.slic3r\/",
  "codeSigningTeamID" : "DKPB65N43Z",
  "codeSigningFlags" : 570495745,
  "codeSigningValidationCategory" : 6,
  "codeSigningTrustLevel" : 4294967295,
  "instructionByteStream" : {"beforePC":"JBRAqUgkQKkhQADRQkAA0QoAABQmHECpSixAqdIBALQfIAPVJBRBqQ==","atPC":"SCRBqcwACvrtAAv6DDSBqCYcwqlKLMKpjAAI+q0ACfoMNIGoUgYA0Q=="},
  "bootSessionUUID" : "0D6A2DBC-CA90-48DA-9079-F97A43709A03",
  "wakeTime" : 158,
  "sleepWakeUUID" : "185E9E36-1067-46A5-AFEF-6C0F30543FEC",
  "sip" : "enabled",
  "vmRegionInfo" : "0x16f900000 is in 0x16f900000-0x16f904000;  bytes after start: 0  bytes before end: 16383\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      Stack                       16f4f8000-16f900000    [ 4128K] rw-\/rwx SM=PRV  thread 4\n--->  STACK GUARD                 16f900000-16f904000    [   16K] ---\/rwx SM=NUL  stack guard for thread 5\n      Stack                       16f904000-16f98c000    [  544K] rw-\/rwx SM=PRV  thread 5",
  "exception" : {"codes":"0x0000000000000002, 0x000000016f900000","rawCodes":[2,6166675456],"type":"EXC_BAD_ACCESS","signal":"SIGBUS","subtype":"KERN_PROTECTION_FAILURE at 0x000000016f900000"},
  "termination" : {"flags":0,"code":10,"namespace":"SIGNAL","indicator":"Bus error: 10","byProc":"exc handler","byPid":3775},
  "vmregioninfo" : "0x16f900000 is in 0x16f900000-0x16f904000;  bytes after start: 0  bytes before end: 16383\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      Stack                       16f4f8000-16f900000    [ 4128K] rw-\/rwx SM=PRV  thread 4\n--->  STACK GUARD                 16f900000-16f904000    [   16K] ---\/rwx SM=NUL  stack guard for thread 5\n      Stack                       16f904000-16f98c000    [  544K] rw-\/rwx SM=PRV  thread 5",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 4,
  "threads" : [{"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":27500675596288},{"value":0},{"value":27500675596288},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":6403},{"value":18944},{"value":0},{"value":18446744073709551569},{"value":8489576424},{"value":0},{"value":4294967295},{"value":2},{"value":27500675596288},{"value":0},{"value":27500675596288},{"value":6158387064},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577772036},"cpsr":{"value":4096},"fp":{"value":6158386912},"sp":{"value":6158386832},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696596},"far":{"value":0}},"id":203985,"name":"slic3r_main","queue":"com.apple.main-thread","frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":7},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":7},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":7},{"imageOffset":514620,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":508572,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":8},{"imageOffset":505636,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":8},{"imageOffset":1094960,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":9},{"imageOffset":1119048,"symbol":"ReceiveNextEventCommon","symbolLocation":676,"imageIndex":9},{"imageOffset":1119496,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":9},{"imageOffset":241716,"symbol":"_DPSNextEvent","symbolLocation":660,"imageIndex":10},{"imageOffset":10089172,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":688,"imageIndex":10},{"imageOffset":188512,"symbol":"-[NSApplication run]","symbolLocation":480,"imageIndex":10},{"imageOffset":42880304,"symbol":"wxGUIEventLoop::OSXDoRun()","symbolLocation":140,"imageIndex":0},{"imageOffset":43944232,"symbol":"wxCFEventLoop::DoRun()","symbolLocation":40,"imageIndex":0},{"imageOffset":43307712,"symbol":"wxEventLoopBase::Run()","symbolLocation":192,"imageIndex":0},{"imageOffset":43111256,"symbol":"wxAppConsoleBase::MainLoop()","symbolLocation":208,"imageIndex":0},{"imageOffset":42617588,"symbol":"wxApp::OnRun()","symbolLocation":36,"imageIndex":0},{"imageOffset":43531004,"symbol":"wxEntry(int&, wchar_t**)","symbolLocation":88,"imageIndex":0},{"imageOffset":12294468,"symbol":"Slic3r::GUI::GUI_Run(Slic3r::GUI::GUI_InitParams&)","symbolLocation":284,"imageIndex":0},{"imageOffset":66696,"symbol":"Slic3r::CLI::run(int, char**)","symbolLocation":22336,"imageIndex":0},{"imageOffset":90064,"symbol":"main","symbolLocation":220,"imageIndex":0},{"imageOffset":25204,"symbol":"start","symbolLocation":2840,"imageIndex":11}]},{"id":204039,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":163857297309696},{"value":0},{"value":163857297309696},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":38151},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8489576424},{"value":0},{"value":4294967295},{"value":2},{"value":163857297309696},{"value":0},{"value":163857297309696},{"value":6160687208},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577772036},"cpsr":{"value":4096},"fp":{"value":6160687056},"sp":{"value":6160686976},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696596},"far":{"value":0}},"frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":7},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":7},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":7},{"imageOffset":514620,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":508572,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":8},{"imageOffset":505636,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":8},{"imageOffset":1440288,"symbol":"_NSEventThread","symbolLocation":148,"imageIndex":10},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}]},{"id":204047,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6161264640},{"value":48143},{"value":6160728064},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6161264640},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":204064,"frames":[{"imageOffset":18156,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":7},{"imageOffset":30868,"symbol":"_pthread_cond_wait","symbolLocation":1204,"imageIndex":13},{"imageOffset":136716,"symbol":"std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l>>>)","symbolLocation":100,"imageIndex":14},{"imageOffset":10431140,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, Slic3r::GUI::UserAccountCommunication::init_session_thread()::$_0>>(void*)","symbolLocation":188,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":260},{"value":0},{"value":4096},{"value":0},{"value":0},{"value":160},{"value":88887},{"value":999998834},{"value":6162411176},{"value":0},{"value":0},{"value":2},{"value":2},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8489593960},{"value":0},{"value":4638336216},{"value":4638336280},{"value":6162411744},{"value":999998834},{"value":88887},{"value":4096},{"value":4097},{"value":4352},{"value":18437520701672696841},{"value":171841360874625}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577965204},"cpsr":{"value":1610616832},"fp":{"value":6162411296},"sp":{"value":6162411152},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577710828},"far":{"value":0}}},{"triggered":true,"id":204065,"threadState":{"x":[{"value":6166675360},{"value":6166675360},{"value":6166675440},{"value":4},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":16140901064495857664},{"value":16},{"value":6166646496},{"value":687},{"value":18446744073709551107},{"value":6166646584},{"value":4},{"value":6166646448},{"value":6166646528},{"value":4},{"value":4},{"value":18446744073709551612},{"value":6166646584},{"value":2},{"value":2}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4327921456},"cpsr":{"value":1610616832},"fp":{"value":6166646736},"sp":{"value":6166646368},"esr":{"value":2449473543,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4327927748,"matchesCrashFrame":1},"far":{"value":6166675456}},"frames":[{"imageOffset":19460036,"symbol":"__gmpn_sub_n","symbolLocation":124,"imageIndex":0},{"imageOffset":19453744,"symbol":"__gmpz_sub","symbolLocation":788,"imageIndex":0},{"imageOffset":18446638524578204099,"imageIndex":12}]},{"id":204068,"frames":[{"imageOffset":3924,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":79364,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":7},{"imageOffset":39672,"symbol":"mach_msg_overwrite","symbolLocation":480,"imageIndex":7},{"imageOffset":4764,"symbol":"mach_msg","symbolLocation":24,"imageIndex":7},{"imageOffset":514620,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":8},{"imageOffset":508572,"symbol":"__CFRunLoopRun","symbolLocation":1212,"imageIndex":8},{"imageOffset":505636,"symbol":"CFRunLoopRunSpecific","symbolLocation":588,"imageIndex":8},{"imageOffset":1010128,"symbol":"CFRunLoopRun","symbolLocation":64,"imageIndex":8},{"imageOffset":44300,"symbol":"-[ConnexionClientAPI clientThreadEntry]","symbolLocation":224,"imageIndex":5},{"imageOffset":347172,"symbol":"__NSThread__start__","symbolLocation":724,"imageIndex":15},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":349657582534656},{"value":0},{"value":349657582534656},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":2},{"value":0},{"value":0},{"value":0},{"value":81411},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8489576424},{"value":0},{"value":4294967295},{"value":2},{"value":349657582534656},{"value":0},{"value":349657582534656},{"value":6167223608},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6577772036},"cpsr":{"value":4096},"fp":{"value":6167223456},"sp":{"value":6167223376},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696596},"far":{"value":0}}},{"id":204080,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6171815936},{"value":130563},{"value":6171279360},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6171815936},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":204549,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169383552},{"value":0},{"value":1},{"value":0},{"value":82},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":3590549505},{"value":3588450306},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081664},{"value":4615707264},{"value":1},{"value":82},{"value":4978081704},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6254915504},"sp":{"value":6254915456},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204550,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553168851648},{"value":0},{"value":1},{"value":1},{"value":80},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":3387009086},{"value":3384909887},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081792},{"value":4864465408},{"value":1},{"value":80},{"value":4978081832},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6259158960},"sp":{"value":6259158912},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204551,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169383808},{"value":0},{"value":1},{"value":0},{"value":81},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":3594749947},{"value":3592648708},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081408},{"value":4863390976},{"value":1},{"value":81},{"value":4978081448},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6263402416},"sp":{"value":6263402368},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204552,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553170724608},{"value":0},{"value":1},{"value":1},{"value":80},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":2845857890},{"value":2843758695},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081152},{"value":4864632960},{"value":1},{"value":80},{"value":4978081192},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6267645872},"sp":{"value":6267645824},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204553,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169399936},{"value":0},{"value":1},{"value":0},{"value":83},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":4286810107},{"value":4284708866},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081536},{"value":4615401344},{"value":1},{"value":83},{"value":4978081576},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6271889328},"sp":{"value":6271889280},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204554,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169448384},{"value":0},{"value":1},{"value":1},{"value":81},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":2977962094},{"value":2975862895},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081280},{"value":4665453184},{"value":1},{"value":81},{"value":4978081320},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6276132784},"sp":{"value":6276132736},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204555,"frames":[{"imageOffset":3792,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":7},{"imageOffset":22805480,"symbol":"tbb::detail::r1::rml::private_worker::run()","symbolLocation":412,"imageIndex":0},{"imageOffset":22805056,"symbol":"tbb::detail::r1::rml::private_worker::thread_routine(void*)","symbolLocation":12,"imageIndex":0},{"imageOffset":29412,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":13},{"imageOffset":8444,"symbol":"thread_start","symbolLocation":8,"imageIndex":13}],"threadState":{"x":[{"value":14},{"value":0},{"value":0},{"value":1},{"value":105553169451520},{"value":0},{"value":1},{"value":0},{"value":81},{"value":4363893992,"symbolLocation":0,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":4363981016,"symbolLocation":87024,"symbol":"tbb::detail::r1::address_waiter_table"},{"value":0},{"value":105553178744224},{"value":2045},{"value":2642608146},{"value":2640508942},{"value":18446744073709551580},{"value":8489596232},{"value":0},{"value":4978081024},{"value":4864473216},{"value":1},{"value":81},{"value":4978081064},{"value":1},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4331273192},"cpsr":{"value":1610616832},"fp":{"value":6280376240},"sp":{"value":6280376192},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577696464},"far":{"value":0}}},{"id":204557,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6160117760},{"value":174595},{"value":6159581184},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6160117760},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":204701,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6158970880},{"value":179979},{"value":6158434304},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6158970880},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":206997,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6161838080},{"value":260855},{"value":6161301504},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6161838080},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":207154,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6159544320},{"value":260203},{"value":6159007744},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6159544320},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":207155,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6168375296},{"value":130851},{"value":6167838720},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6168375296},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}},{"id":207266,"frames":[{"imageOffset":8424,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":13}],"threadState":{"x":[{"value":6168948736},{"value":261691},{"value":6168412160},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6168948736},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6577942760},"far":{"value":0}}}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4308467712,
    "CFBundleShortVersionString" : "PrusaSlicer PrusaSlicer-2.9.0",
    "CFBundleIdentifier" : "com.prusa3d.slic3r\/",
    "size" : 53395456,
    "uuid" : "2398bcea-e91a-3632-a8d2-367669fbca4c",
    "path" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/MacOS\/PrusaSlicer",
    "name" : "PrusaSlicer",
    "CFBundleVersion" : "PrusaSlicer-2.9.0"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4391337984,
    "size" : 704512,
    "uuid" : "50bb16ab-207a-38ca-9641-7ea02ee57990",
    "path" : "\/private\/var\/folders\/*\/PrusaSlicer.app\/Contents\/Frameworks\/libzstd.1.5.6.dylib",
    "name" : "libzstd.1.5.6.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4593565696,
    "size" : 49152,
    "uuid" : "fcf9b985-2748-371b-98d3-37a06a9bf107",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4620075008,
    "CFBundleShortVersionString" : "323.15",
    "CFBundleIdentifier" : "com.apple.AGXMetal13-3",
    "size" : 6963200,
    "uuid" : "0253a4e5-17e3-37f5-acf3-f698f08fa3a9",
    "path" : "\/System\/Library\/Extensions\/AGXMetal13_3.bundle\/Contents\/MacOS\/AGXMetal13_3",
    "name" : "AGXMetal13_3",
    "CFBundleVersion" : "323.15"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4655611904,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.AppleMetalOpenGLRenderer",
    "size" : 425984,
    "uuid" : "d066b74f-d423-38de-9a8d-16b1bcddb1c7",
    "path" : "\/System\/Library\/Extensions\/AppleMetalOpenGLRenderer.bundle\/Contents\/MacOS\/AppleMetalOpenGLRenderer",
    "name" : "AppleMetalOpenGLRenderer",
    "CFBundleVersion" : "1"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4661624832,
    "CFBundleShortVersionString" : "1.3.3",
    "CFBundleIdentifier" : "com.3dconnexion.driver.client",
    "size" : 65536,
    "uuid" : "10a99a6c-2c58-3b9d-a2a6-f204869a06f5",
    "path" : "\/Library\/Frameworks\/3DconnexionClient.framework\/Versions\/A\/3DconnexionClient",
    "name" : "3DconnexionClient",
    "CFBundleVersion" : "1.3.3.446"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 5658361856,
    "CFBundleShortVersionString" : "3.0",
    "CFBundleIdentifier" : "com.apple.security.csparser",
    "size" : 131072,
    "uuid" : "2a2de3cc-2e01-35ae-8386-e51c0bb4070f",
    "path" : "\/System\/Library\/Frameworks\/Security.framework\/Versions\/A\/PlugIns\/csparser.bundle\/Contents\/MacOS\/csparser",
    "name" : "csparser",
    "CFBundleVersion" : "61439.60.117"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577692672,
    "size" : 241656,
    "uuid" : "dfc9530c-e75b-3d1c-a9a6-85c8a709d6a7",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6578401280,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5197824,
    "uuid" : "41fdd393-3acc-328d-8108-e59a3a947ec5",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "3208"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6767964160,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3178496,
    "uuid" : "83159ee1-0ca4-3a91-887a-db80b7029337",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6640967680,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 21204992,
    "uuid" : "4251ee1c-062c-3b9a-b6e2-751f77ef9f4a",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2575.30.19"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6574268416,
    "size" : 532288,
    "uuid" : "4ce86d18-f3fa-3d2a-a1b8-e7cd8a52fb0d",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577934336,
    "size" : 53248,
    "uuid" : "f1661613-b1c8-320d-b69d-97f174130e29",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6577000448,
    "size" : 581628,
    "uuid" : "fe5f2fbb-d3b5-30bc-bad8-3571ac2a72a0",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6597214208,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 14979072,
    "uuid" : "b39c1e42-f15f-3671-b63e-6be7bdad0fcd",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
  "sharedCache" : {
  "base" : 6573457408,
  "size" : 4861722624,
  "uuid" : "e36100c7-89e7-3970-8938-8483ccd7019a"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.7G resident=0K(0%) swapped_out_or_unallocated=1.7G(100%)\nWritable regions: Total=2.9G written=1574K(0%) resident=1574K(0%) swapped_out=0K(0%) unallocated=2.9G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               256K        2 \nActivity Tracing                   256K        1 \nCG image                          11.8M      224 \nCG raster data                     272K        1 \nColorSync                          768K       38 \nCoreAnimation                     2720K       92 \nCoreGraphics                        48K        3 \nCoreUI image data                 2576K       20 \nFoundation                          48K        2 \nKernel Alloc Once                   32K        1 \nMALLOC                             2.8G       81 \nMALLOC guard page                  288K       18 \nOpenGL GLSL                        256K        3 \nSTACK GUARD                       56.3M       20 \nStack                             46.1M       22 \nVM_ALLOCATE                       24.5M      130 \n__AUTH                            5203K      668 \n__AUTH_CONST                      69.8M      910 \n__CTF                               824        1 \n__DATA                            25.4M      892 \n__DATA_CONST                      25.4M      922 \n__DATA_DIRTY                      2757K      337 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__INFO_FILTER                         8        1 \n__LINKEDIT                       632.7M        8 \n__OBJC_RW                         2373K        1 \n__TEXT                             1.0G      945 \n__TPRO_CONST                       272K        2 \ndyld private memory                 48K        2 \nmapped file                      268.5M       35 \nowned unmapped memory             15.1M        1 \npage table in kernel              1574K        1 \nshared memory                      912K       15 \n===========                     =======  ======= \nTOTAL                              5.0G     5401 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "logWritingSignature" : "3da12ee2de9ce51c3d4666e88534a4c277e79ee6",
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "64c17a9925d75a7281053d4c",
      "factorPackIds" : {
        "SIRI_AUDIO_DISABLE_MEDIA_ENTITY_SYNC" : "64d29746ad29a465b3bbeace"
      "deploymentId" : 240000002
      "rolloutId" : "63f9578e238e7b23a1f3030a",
      "factorPackIds" : {
      "deploymentId" : 240000005
  "experiments" : [
Model: MacBookPro17,1, BootROM 11881.61.3, proc 8:4:4 processors, 8 GB, SMC
Graphics: Apple M1, Apple M1, Built-In
Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
Memory Module: LPDDR4, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Sep 28 2024 04:40:32 version 18.20.462.0.7.8.175 FWID 01-10fa77df
IO80211_driverkit-1345.8 "IO80211_driverkit-1345.8" Nov  9 2024 17:02:32
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
Veröffentlicht : 08/01/2025 1:58 pm
So it looks like some sort of memory read fault in thread 4 ... apart from running some memory checks I have no ideas.
I assume you are making some sort of clip-on label.  It's often quicker to start from scratch than to diagnose a complicated painting issue; painting is intended as a fall back in case the original CAD is unavailable but CAD is the proper place for multicolour work.
Attached is a quick interpretation of what I imagine your build sheet intentions are.  Unzip and then import both file as parts, not objects, and you will be able to assign different extruders to the parts and slice.  If it's of use I can post the CAD file for you to tweak/refine to requirements.
Veröffentlicht : 09/01/2025 7:33 am
Antonio
(@antonio-2)
Hi Diem,
thanks for your patience, I opted for a painting of the model because I have to do 56 different numbers, so for me it is easier to do one without a number, import it on slicer, then apply the number, copy and paste it 10 times per print (so for 5 prints) and change with increasing numbers the various clips by modifying only the text for each object. Yours would be the right method but for me, mine method, would be the fastest and simplest, I am self-taught with Fusion and I do not know it perfectly.
Veröffentlicht : 09/01/2025 1:30 pm
It's much faster to use a parametric generator.  Copy this script and paste it into OpenSCAD; you may need to tweak a couple of variables where I had to guess the values but once set just change the label text and run the script twice, once for the body and once for the labels - to generate the STLs for a full print sheet.
// labelclip
// modify as required
labeltext="8";
part=0;  // 0=part body  1=label text
arc=270;  // degrees - how much of circle
insidediameter=40;
enddiameter=8;
thickness=5;
tubeheight=50;
labelvector=[90,180,270]; // degrees - where to put label text
// end of user modifiable varibles
$fn=100; // accuracy
for(y=[0:2]){
  for(x=[0:2]){
    translate([(insidediameter+thickness*2-5)*x,(insidediameter+thickness*2+2)*y,0]){
      item();
translate([(insidediameter+thickness*2-5)*3,(insidediameter+thickness*2+2),0]){
  item();
module item(){
  if(part==0){
    difference(){
      body();
      marks();
  } else {
    intersection(){
      body();
      marks();
module body(){
  rotate([0,0,(360-arc)/2]){
    rotate_extrude(angle=arc){
      profile();
    translate([insidediameter/2+thickness/2,0,0]){
      cylinder(d=enddiameter,h=tubeheight);
    rotate([0,0,arc]){
module marks(){
  for(a=labelvector){
    rotate([0,0,a]){
      translate([0,0,tubeheight/3]){
        wraptext(labeltext,tubeheight/3,50,insidediameter/2+thickness/2,thickness);
module profile(){
  polygon(points=[[insidediameter/2,0],[insidediameter/2+thickness-1,0],[insidediameter/2+thickness,1],[insidediameter/2+thickness,tubeheight-1],[insidediameter/2+thickness-1,tubeheight],[insidediameter/2,tubeheight]]);
module wraptext(t,size,arc,rad,ext){
  step=arc/len(t);
  for(a=[0:len(t)]){
    rotate([0,0,-arc/2+step*a]){
      translate([rad,0,0]){
        rotate([90,0,90]){
          linear_extrude(height=ext){
            text(t[a],size=size,halign="center");
 It should be a *lot* quicker than painting.
Veröffentlicht : 09/01/2025 3:06 pm
