Problem with slicing of sharp edge
Jonas Gustavsson
(@jonas-gustavsson)
Miembro
Hi!
When I slice a model I've made i get a problem with the edge of a vertical wing profile:
Slice Problem
The original model does not show this kind of problem:
Original model
Does anybody know a workaround for this kind of problem?
_/onas
Best Answer by JoanTabb:
If the edge is too thin, slicer will have difficulty resolving the model
the thinnest portion of the model needs to be equal to the nozzle extrusion width
IF the model has 'pointed' edges on the fins it is unlikely that there is an easy fix.  XY Size correction may help if set to say 0.4mm     unfortunately with a sharp edge this may simply move the issue further out on the fin.
Similarly using a smaller diameter nozzle may help, at the expense of longer print times. but again, if the fin is pointed on the edge, this may simply move the issue further out on the fin.
Ultimately it may be easier to sand the edges smooth after printing
Respondido : 24/07/2024 10:44 am
RE: Problem with slicing of sharp edge
Respondido : 24/07/2024 10:52 am
Jonas Gustavsson
(@jonas-gustavsson)
Miembro
Thanks for your reply! I've made the model myself - hence I'll try to do the edge less sharp.
Respondido : 24/07/2024 11:04 am
Also sometimes using classic slicing instead of Arachne can also help.  It has more trouble with thin edges than classic from personal observation.
Respondido : 24/07/2024 12:02 pm
