Printing out two objects with different color results in failure
I have molar tooth and nerves of it. I have extracted them from Cone Beam Tomography and other softwares.
I have scaled up these objects.
I have intented to print out tooth as transparent and nerve as red with pla.
I have used lightening infill with %15 to hold the nerve in the air(seems to be in the air).
My Gcode is;
G21 ; metric values G90 ; absolute positioning M82 ; set extruder to absolute mode ;P2PP PALETTE3_PRO ;P2PP PALETTE3_PRO ;P2PP PRINTERPROFILE=12345678901234567890123456789012 ;P2PP SPLICEOFFSET=40 ;P2PP MINSTARTSPLICE=130 ;P2PP MINSPLICE=90 ;P2PP EXTRAENDFILAMENT=150 ;P2PP LINEARPINGLENGTH=350 ;P2PP MATERIAL_DEFAULT_1_2_1 ;P2PP MATERIAL_PLA_PLA_2_1_2 ;P2PP ABSOLUTEEXTRUDER ;P2PP SIDEWIPELOC=X254 ;P2PP SIDEWIPEMINY=45 ;P2PP SIDEWIPEMAXY=195 ;P2PP SIDEWIPECORRECTION=1.0 ;set !P2PP SIDEWIPELOC=X254 ;set !P2PP SIDEWIPEMINY=45 ;set SIDEWIPEMAXY to the same value as SIDEWIPEMINY ;set !P2PP SIDEWIPEMAXY=45 ;set WIPEFEEDRATE is required to override default value!! ;set !P2PP WIPEFEEDRATE=200 ;P2PP PURGETOWERDELTA=0 ;P2PP FULLPURGEREDUCTION ;P2PP WIPEFEEDRATE=3000 ;P2PP AUTOADDPURGE M140 S[first_layer_bed_temperature] ; set bed temp G28 X0 Y0 ; home X and Y G28 Z0 ; home Z G1 Z30 F{machine_max_feedrate_z[0]*60} ; move Z a bit down to not blow on the bed edge while heating G1 X10 F3900 ; let some space on x to prevent the filament cooling exhaust from beeing blocked by the servo motor M190 S[first_layer_bed_temperature] ; wait for bed temp M104 S[first_layer_temperature] ; set extruder temp M106 S80 ; turn on fan to prevent air nozzle melt while heating up M109 S[first_layer_temperature] ; wait for extruder temp M107 ; start with the fan off G28 X0 ; goto X home again G92 E0 ; zero the extruded length G1 Z0.2 F360 ; move plattform upwards ; extrude material next to the plattform (comment or remove following lines to disable) G1 F180 E20 ; extrude some material next to the plattform G92 E0 ; zero the extruded length G1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract G92 E0 ; zero the extruded length again G1 X5 F3900 ; move sideways to get rid of that string G1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters G92 E0 ; zero the extruded length again ; draw intro line (comment or remove following lines to disable) G1 X30 E5 F700 ; draw intro line G92 E0 ; zero the extruded length G1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract G1 X40 Z2.0 ; move away from the introline G92 E0 ; zero the extruded length again G1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters ; end of intro line code M117 Printing... G5
What I got from printer is;
My question is:
Why the molar tooth and infill is colored even if I selected the extruder 1 which is transparent PLA for molar tooth?
Note;
I have palette pro 3 and anycubic 4max pro 2 as hardware and p2pp and prusaslicer as software.
RE: Printing out two objects with different color results in failure
UPDATE:
When I have run the prusa slicer with p2pp, I got the below preview of 3d print.
In the fail-print, I got the support as colored with red, too. When I have trying to assign support with extruder 1 which is transparent PLA, wipe tower is closed down.
