Printing out two objects with different color results in failure
Fatih Hamırcu
(@fatih-hamircu)
I have molar tooth and nerves of it. I have extracted them from Cone Beam Tomography and other softwares.
I have scaled up these objects.
I have intented to print out tooth as transparent and nerve as red with pla.
I have used lightening infill with %15 to hold the nerve in the air(seems to be in the air).
My Gcode is;
G21 ; metric values
G90 ; absolute positioning
M82 ; set extruder to absolute mode
;P2PP PALETTE3_PRO
;P2PP PALETTE3_PRO
;P2PP PRINTERPROFILE=12345678901234567890123456789012
;P2PP SPLICEOFFSET=40
;P2PP MINSTARTSPLICE=130
;P2PP MINSPLICE=90
;P2PP EXTRAENDFILAMENT=150
;P2PP LINEARPINGLENGTH=350
;P2PP MATERIAL_DEFAULT_1_2_1
;P2PP MATERIAL_PLA_PLA_2_1_2
;P2PP ABSOLUTEEXTRUDER
;P2PP SIDEWIPELOC=X254
;P2PP SIDEWIPEMINY=45
;P2PP SIDEWIPEMAXY=195
;P2PP SIDEWIPECORRECTION=1.0
;set !P2PP SIDEWIPELOC=X254
;set !P2PP SIDEWIPEMINY=45
;set SIDEWIPEMAXY to the same value as SIDEWIPEMINY
;set !P2PP SIDEWIPEMAXY=45
;set WIPEFEEDRATE is required to override default value!!
;set !P2PP WIPEFEEDRATE=200
;P2PP PURGETOWERDELTA=0
;P2PP FULLPURGEREDUCTION
;P2PP WIPEFEEDRATE=3000
;P2PP AUTOADDPURGE
M140 S[first_layer_bed_temperature] ; set bed temp
G28 X0 Y0 ; home X and Y
G28 Z0 ; home Z
G1 Z30 F{machine_max_feedrate_z[0]*60} ; move Z a bit down to not blow on the bed edge while heating
G1 X10 F3900 ; let some space on x to prevent the filament cooling exhaust from beeing blocked by the servo motor
M190 S[first_layer_bed_temperature] ; wait for bed temp
M104 S[first_layer_temperature] ; set extruder temp
M106 S80 ; turn on fan to prevent air nozzle melt while heating up
M109 S[first_layer_temperature] ; wait for extruder temp
M107 ; start with the fan off
G28 X0 ; goto X home again
G92 E0 ; zero the extruded length
G1 Z0.2 F360 ; move plattform upwards
; extrude material next to the plattform (comment or remove following lines to disable)
G1 F180 E20 ; extrude some material next to the plattform
G1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract
G92 E0 ; zero the extruded length again
G1 X5 F3900 ; move sideways to get rid of that string
G1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters
; draw intro line (comment or remove following lines to disable)
G1 X30 E5 F700 ; draw intro line
G1 X40 Z2.0 ; move away from the introline
; end of intro line code
M117 Printing...
G5
 What I got from printer is;
My question is:
Why the molar tooth and infill is colored even if I selected the extruder 1 which is transparent PLA for molar tooth?
Note;
I have palette pro 3 and anycubic 4max pro 2 as hardware and p2pp and prusaslicer as software.
Napsal : 22/12/2023 5:04 pm
Fatih Hamırcu
(@fatih-hamircu)
RE: Printing out two objects with different color results in failure
UPDATE:
When I have run the prusa slicer with p2pp, I got the below preview of 3d print.
In the fail-print, I got the support as colored with red, too. When I have trying to assign support with extruder 1 which is transparent PLA, wipe tower is closed down.
Napsal : 22/12/2023 5:20 pm
