Printing Different Objects with Different Print Settings/Profiles
SkeletalPrints
(@skeletalprints)
Having different objects printed with different pre-defined settings. Example;
I want to print a DnD mini and a DnD wall simultaneously for an overnight print. I like the mini to be printed with profile "detail", and the wall to be printed with profile "speed".
Is there any way to do that?
This is more of a feature request because I see no current way of doing that. (If so I will repost on GitHub)
Opublikowany : 19/07/2022 12:53 am
Swiss_Cheese
(@swiss_cheese)
RE: Printing Different Objects with Different Print Settings/Profiles
Slicer has all the features to do this currently, you  should study on how to use Slicer, as you learn it, you will discover what features do what. It sounds as though you are pretty new to PrusaSlicer, here is a link of some basic things to help get you started.
https://help.prusa3d.com/category/prusaslicer_204
There is a great deal to learn, after you get the basics, this community is a great place to get answers to specific questions, if you find yourself searching the forum for a topic or answer that may already exist, it's best to use Google and direct your search at the prusa forums e.g. (Prusa forums how to set layer height), or how to adjust infill, etc.
Good luck and have fun.
Swiss_Cheese
The Filament Whisperer
Opublikowany : 19/07/2022 1:13 am
SkeletalPrints
(@skeletalprints)
I have owned my Mk3 for 3.5 years now and am familiar with PrusaSlicer. I believe I might have phrased my question badly(though I could be overlooking something).
I want to have different objects with completely different profiles not just with the "objects settings" menu.
I could use that menu to do what I want, but It would take extremely long to change all the settings to line up with another one of my profiles.
I want to say Mini Print with "0.15mm EXTRA DETAIL @0.6 - Minis" and my other part to print with "0.40mm SPEED @0.6 - V1.1"
Opublikowany : 19/07/2022 1:26 am
backslashv
(@backslashv)
Were you able to find a solution?
Opublikowany : 14/10/2025 2:03 am
