Printer settings specific to material
K D
 K D
(@k-d)
Hello all,
I want to allocate some of the printer settings to material settings - such as First layer height and printing speeds.
How would I make this modification to the default allocations?
Opublikowany : 06/09/2024 7:18 pm
RE: Printer settings specific to material
If I understand your question correctly, you can't.  Settings are on the tab/section they are on and are not moveable.  The Filament profile has a certain number of over rides available but not layer height or speeds.
Well I suppose you could load the code base, rewrite it to do what you want and then compile and build your own version.  Seems a bit excessive though.
Opublikowany : 07/09/2024 12:05 am
You can't, not without editing and recompiling the source code.
But it's easy to make a new print profile and save it as, eg., '0.2mm QUALITY for Filament XYZ' and load it when required.
Opublikowany : 07/09/2024 12:11 am
