Printer settings specific to material
Hello all,
I want to allocate some of the printer settings to material settings - such as First layer height and printing speeds.
How would I make this modification to the default allocations?
RE: Printer settings specific to material
If I understand your question correctly, you can't. Settings are on the tab/section they are on and are not moveable. The Filament profile has a certain number of over rides available but not layer height or speeds.
Well I suppose you could load the code base, rewrite it to do what you want and then compile and build your own version. Seems a bit excessive though.
You can't, not without editing and recompiling the source code.
But it's easy to make a new print profile and save it as, eg., '0.2mm QUALITY for Filament XYZ' and load it when required.
