Printer Settings for Slicer (i3 MK3S+)
Omega-TI
(@omega-ti)
I recently downloaded the slicer software, and it comes with one configuration setting... for the MINI.  Is there any difference between things sliced for the MINI and my printer the i3 MK3S+?  When I try to print, the display comes back telling me it was sliced for a different printer. Can I simply change the file name or do I need to obtain different settings.  If so, how?
Thanks.
Respondido : 30/08/2022 2:18 pm
RE: Printer Settings for Slicer (i3 MK3S+)
There’s massive differences. Do not print files sliced for a different printer. When you install PRUSA slicer or after it is installed you can run the configuration wizard and choose the printers to install. You need to install the one matching your printer. Then when slicing you should make sure that the correct printer is selected on the drop downs when sliced.
Please go read the PRUSA slicer knowledge base to learn the basics. Once you have done that then come back here with any questions. https://help.prusa3d.com/category/prusaslicer_204
Respondido : 30/08/2022 2:22 pm
1 les gusta
