Printer profiles for prusaslicer?
Nathaniel Stenzel
(@nathaniel-stenzel)
Hi, all. I hope I am putting this in the right place.
I was hoping to find a profile to use with PrusaSlicer for the Monoprice Mini Delta Printer (MPMD).
I am also looking for a profile for the Voxelab Aquila.
Could someone point me in the right direction?
Cura has been getting less and less friendly and it rejects the old profiles that I already had set up. It's open source repository is also bullshit because it is really just pulling the source code from a different version control system and it will not compile. Their github is basically a scam. I am hoping I can get acclimated to  using Prusaslicer again and keep the profiles for use with upcoming versions of Prusaslicer.
Opublikowany : 01/04/2025 3:52 am
RE: Printer profiles for prusaslicer?
All the non prusa profiles are submitted by users.  There doesnt appear to be those available in the config wizard so I suspect no one has submitted one to Prusa for inclusion as yet.
You could add your own though and once working you could submit it to help other users out.  You might be able to find someone on a monoprice or voxelab specific forum who has one they would be willing to share.
For reference the repo for non prusa printer submissions for FDM is here https://github.com/prusa3d/PrusaSlicer-settings-non-prusa-fff
Its not that hard to add your own.  Just did a quick google search and a reddit post mentions just using a Ender 2 v3 profile for the voxelab that worked as its pretty much a clone of that printer.
Opublikowany : 01/04/2025 9:44 am
Also just found this for the mini delta https://github.com/aegean-odyssey/PrusaSlicer-settings
Opublikowany : 01/04/2025 9:46 am
Nathaniel Stenzel
I did finally run into that but I did not successfully import anything from it.
Opublikowany : 02/04/2025 3:11 am
O-Works
(@o-works)
Hi, I tried making a custom profile for my IIIP monoprice mini delta and when i try to print with it, the nozzle doesn't even come close to the plate. it's like 8mm off. can anyone help?
Opublikowany : 27/09/2025 5:59 pm
