Print Width Displayed Incorrectly
Just upgraded from V2.2 to V2.3 and if you use large print widths the displayed print is not accurate after slicing. For example 2mm nozzle with a print width of 3mm shows a 2mm print width for some reason after slicing. This was not the case in V2.2. I have not tried printing to see is the gcode is correct.
RE: Print Width Displayed Incorrectly
Please save your part and settings off in a 3MF project file, zip it up, and attach it to a reply here. That way we can see everything you're working with and provide better suggestions.
I didn’t see any difference between versions. As Bob said, upload the 3mf so we can check the settings.
@bobstro @fuchsr
Thanks for responding so quickly. Project file attached. Also images from 2.2 and 2.3
Edit: Yes setting are a little odd compared to your average print but are needed for the unique printing application.
Bump.
I'm still seeing the same issue in 2.4.0 Beta1. Added a simple bowel width a 4mm print width and the slicer preview shows a print width of 2mm.
Please report PrusaSlicer bugs over on the official GitHub site: https://github.com/prusa3d/PrusaSlicer/issues
