Print Width Displayed Incorrectly
E
 E
(@e)
Just upgraded from V2.2 to V2.3 and if you use large print widths the displayed print is not accurate after slicing.  For example 2mm nozzle with a print width of 3mm shows a 2mm print width for some reason after slicing.  This was not the case in V2.2.  I have not tried printing to see is the gcode is correct.
Napsal : 18/03/2021 1:50 pm
RE: Print Width Displayed Incorrectly
Please save your part and settings off in a 3MF project file, zip it up, and attach it to a reply here. That way we can see everything you're working with and provide better suggestions.
Napsal : 18/03/2021 2:25 pm
I didn’t see any difference between versions.  As Bob said, upload the 3mf so we can check the settings.
Napsal : 18/03/2021 2:40 pm
E
 E
(@e)
@bobstro @fuchsr
Thanks for responding so quickly.  Project file attached.  Also images from 2.2 and 2.3
Width Issue
Edit: Yes setting are a little odd compared to your average print but are needed for the unique printing application.
This post was modified před 5 years by E
Napsal : 18/03/2021 3:55 pm
E
 E
(@e)
Bump.
I'm still seeing the same issue in 2.4.0 Beta1.  Added a simple bowel width a 4mm print width and the slicer preview shows a print width of 2mm.
Napsal : 22/11/2021 1:44 pm
3Delight
(@3delight)
Moderátor Moderator
Please report PrusaSlicer bugs over on the official GitHub site: https://github.com/prusa3d/PrusaSlicer/issues
Napsal : 22/11/2021 2:40 pm
