print sequence brim in combination with "Complete individual objects"
i have to print a relative small object (4.5 x 11.2 x 6mm) in a bigger quantity. As the object is small i use brim support.
When i want to use the option "Complete individual objects", why all brims will be printed first and only afterwards will the object itself be printed one after the other?
Stefan
Veröffentlicht : 14/01/2021 8:02 am
RE: print sequence brim in combination with "Complete individual objects"
The objects in your pic should print fine without a brim.
I print significantly smaller objects on a very regular basis (such as just a 6mm threaded rod) without any brim at all and without issue.
If you have a clean build plate, your Live Z adjusted well and set the first layer to print at somewhere in the 12-15mm/s range, adhesion shouldn't be a problem.
Veröffentlicht : 14/01/2021 12:18 pm
