Print only part of object solid
Al Simons
(@al-simons)
Is it possible to tell PrusaSlicer to print part of an object solid with the rest 20% infill, or is infill uniform for an object? Slicing for an MK3S+.
Thanks very much for your help.
-Al
Respondido : 18/11/2021 8:02 pm
sylviatrilling
(@sylviatrilling)
RE: Print only part of object solid
See https://help.prusa3d.com/en/article/modifier-meshes-custom-supports-and-other-magic_114258
Mk3S+,SL1S
Respondido : 18/11/2021 8:56 pm
Swiss_Cheese
(@swiss_cheese)
@al-simons
Is it possible to tell PrusaSlicer to print part of an object solid with the rest 20% infill?
yes, you can do this through the use of modifiers, if the video and brief tutorial about modifiers doesn't do the trick for you, come back and let us know and we can give you some examples more specific to your situation.
Good Luck
Swiss_Cheese
The Filament Whisperer
Respondido : 18/11/2021 9:13 pm
1 les gusta
Al Simons
(@al-simons)
Thanks, sylviatrilling and Swiss_Cheese!  Layer modification worked perfectly.  I really appreciate your quick replies. I was able to abort the print I was doing inefficiently (all solid) in its early stages and do it right.
-Al
Respondido : 18/11/2021 10:46 pm
1 les gusta
