Post-processing script not running
edensan
(@edensan)
hi all..
i have a python script that run fine in cura.
can prusaslicer does this also?
from cura.Snapshot import Snapshot
from PyQt5.QtCore import Qt
import os
import base64
class ShuiPreview(Script):
  def __init__(self):
    super().__init__()
  def getSettingDataString(self):
    return """{
              "name": "Generate SHUI Preview",
              "key": "shui_preview",
              "metadata": {},
              "version": 2,
              "settings": {
                  "size": {
                      "label": "Size",
                      "description": "Size of small preview",
                      "type": "enum",
                      "options": {
                        "50": "small",
                        "100": "big",
                        "0": "none"
                      "default_value": "50"
                  "format": {
                      "label": "Format",
                      "description": "Format preview code",
                      "type": "enum",
                      "options": {
                        "shui": "SHUI",
                        "mks": "MKS"
                      "default_value": "shui"
  def addScreenshot(self, img, width, height, img_type):
    result = ""
    b_image = img.scaled(width, height, Qt.KeepAspectRatio)
    img_size = b_image.size()
    result += img_type
    datasize = 0
    for i in range(img_size.height()):
      for j in range(img_size.width()):
        pixel_color = b_image.pixelColor(j, i)
        r = pixel_color.red() >> 3
        g = pixel_color.green() >> 2
        b = pixel_color.blue() >> 3
        rgb = (r << 11) | (g << 5) | b
        strHex = "%x" % rgb
        if len(strHex) == 3:
          strHex = '0' + strHex[0:3]
        elif len(strHex) == 2:
          strHex = '00' + strHex[0:2]
        elif len(strHex) == 1:
          strHex = '000' + strHex[0:1]
        if strHex[2:4] != '':
          result += strHex[2:4]
          datasize += 2
        if strHex[0:2] != '':
          result += strHex[0:2]
          datasize += 2
        if datasize >= 50:
          datasize = 0
      result += '\rM10086 ;'
      if i == img_size.height() - 1:
        result += "\r"
    return result
  def generate_mks(self, sz, data):
    image = Snapshot.snapshot(width = 900, height = 900)
    if sz == "50":
      pv = self.addScreenshot(image, 50, 50, ";simage:")
    else:
      pv = self.addScreenshot(image, 100, 100, ";simage:")
    pv = pv + self.addScreenshot(image, 200, 200, ";;gimage:")
    data.insert(0,  pv)
    return data
  def generate_shui(self, sz, data):
    pv=""
    if sz == "50":
      pv=pv+";SHUI PREVIEW 50x50\n" + self.generate(image, 50)
    else:
      pv=pv+";SHUI PREVIEW 100x100\n" + self.generate(image, 100)
    pv=pv+self.generate(image, 200)
    data.insert(0,  pv)
    return data
  def execute(self, data):
    sz=self.getSettingValueByKey("size")
    if sz=="0":
      return data
    fmt=self.getSettingValueByKey("format")
    if fmt=="shui":
      return self.generate_shui(sz, data)
    if fmt=="mks":
      return self.generate_mks(sz, data)
    return data
  def generate(self, img, size):
    result = ""
    b_image = img.scaled(size, size, Qt.KeepAspectRatio)
    datasize = 0
      row = bytearray()
        row.append((rgb >> 8) & 0xFF)
        row.append(rgb & 0xFF)
      result += ";" + base64.b64encode(row).decode('utf-8') + "\n"
    return result
would this be possible?
greetz Edwin
Opublikowany : 11/12/2022 12:30 pm
In Print Settings > Output options you can call a post process script.
... but don't expect Cura specific code to complete without porting.
Opublikowany : 11/12/2022 12:53 pm
edensan
(@edensan)
RE: Post-processing script not running
i did call to this script but slicer give error cant find script.
Opublikowany : 11/12/2022 2:05 pm
edensan
(@edensan)
its normal python script mabe someone can port?
 You need to give the path to the script just as you would with any other program and the file permissions may need to be set.
I don't know which operating system you are using but it may be something like: ~/3dfiles/myscripts/myscript.py
 - and it looks like your script imports a library; it would be best to contact the author of the library who might have, or be working on, a port.
Opublikowany : 12/12/2022 8:03 am
edensan
(@edensan)
Posted by: @diem
I don't know which operating system you are using but it may be something like: ~/3dfiles/myscripts/myscript.py i use wondows
i use Windows 10 64 bit so i cant set permissions right?
thx for reply
This post was modified 3 years temu by edensan
Opublikowany : 13/12/2022 11:28 am
I haven't used Windows seriously this century ... but I'm pretty sure they use permissions still, hang on, yes:
A search for 'windows 10 file permissions' turns up some potentially useful pages.
Opublikowany : 14/12/2022 2:31 pm
