Please fix the speed modifiers.
Alex
 Alex
(@alex-15)
Hello everyone, please make a change. If you apply a modifier to an object to change the speed, the speed of the perimeters. Then when cutting, the affected side is formed as a separate element with a separate perimeter. Is it possible to make sure that where the modifier is applied, it is the speed on that side that changes, without adding additional perimeters, which essentially change the geometry and strength of the object.
Best Answer by Neophyl:
No it is not possible to do that with the current software.  Any important change results in the areas being sliced separately.  This leads to the effect you have observed.
Also this is a user to user forum.  Requests here mean nothing.  The devs do not hang out here and very rarely interact here.
All feature requests have to be made at the Prusa Slicer github repository.  Your request already exists though and has for a long time (years).  For example https://github.com/prusa3d/PrusaSlicer/issues/4202 (from 2020)
There are others too. It is basically a long standing open issue.  However fixing it is not as important as adding new flashy features (obviously).
Ce sujet a été modifié il y a 2 years 4 fois par Alex
Publié : 17/01/2024 5:01 pm
RE: Please fix the speed modifiers.
Publié : 17/01/2024 5:20 pm
