PLA Temperature default
mburmester
(@mburmester)
beginner question:
in PrusaSlicer the default nozzle temperature for PLA is set to 230 degrees. Everywhere else (like on the spools) it says maximum 215 or 220 degrees. What's going on here? Am I missing something?
Cheers,
Martin
Opublikowany : 27/01/2025 6:40 pm
RE: PLA Temperature default
Are you looking at MK4, or XL profiles?
These often use higher temperatures for faster printing.
Joan
Opublikowany : 27/01/2025 6:48 pm
mburmester
(@mburmester)
That is MK4S, yes.
Opublikowany : 27/01/2025 7:17 pm
They've upped the temp recently, I assume to facilitate printing at higher speeds and with a high flow nozzle.
Opublikowany : 27/01/2025 7:18 pm
mburmester
(@mburmester)
Does that work for the bed temperature as well? Use what the filament manufacturer says or something higher?
Opublikowany : 04/02/2025 6:42 pm
I usually use 70C for PLA
Joan
Opublikowany : 04/02/2025 8:51 pm
To be honest, I never look at the spools. Unless there's a brand-specific profile, I just run everything with Generic or Prusament profiles. Only in the (very rare) case that I see issues, I run a temp tower. For bed temps I still have to come across anything that requires me to adjust the (Prusa) temperature, and I currently have 80+ materials/colors in use.
Opublikowany : 04/02/2025 9:23 pm
1 ludzie polubili
Brian
(@brian-12)
230 is necessary imo for PLA on the MK4S or you risk underextrusion for the reasons @foxrun3d mentioned.
I've actually bumped it up to 235 occasionally when using the speed profile because I was seeing changes in the sheen of the material when it was printing solid infill.
Opublikowany : 05/02/2025 1:44 am
Sebastian Barchak
(@sebastian-barchak)
How about in the Core One? It defaults to 230* but it runs in an internal chamber? It also defaults the chamber to 20* and runs the fans at your max setting the entire time? Is this normal? Granted I'm only 2 weeks and nearing one PLA spool consumed into the printing world.
Opublikowany : 06/02/2026 7:32 pm
