Perimeter not connected big gaps, big .STL file
[Risolto] Perimeter not connected big gaps, big .STL file
Karolis S
(@karolis-s)
Hello,
Its realy big print 600x400x450
Why slicer is doing that ? Sometimes it makes good perimeters sometimes not with same profile..
PC settings :
intel i7-7820x
48gb ram
Quadro P4000
Best Answer by Karolis S:
Added option :
Before Layer Change in printer configuration :
G92 E0
Still cant understant why sometimes it worked. 😀
Postato : 19/07/2021 9:40 am
Project file please
For any reasonable help we need your project file.  There are far too many things that could impact slicing.  You need to File>Save Project then take the resulting .3mf file and zip it into an archive.  It must be zipped for the forum to accept the file type.
With a project file we can then see all your settings in use and debug things with much easier.  Its a snapshot of everything active , so printer, model, any modifiers etc that may be in play.  Without its all just guesswork.
Postato : 19/07/2021 10:36 am
Karolis S
(@karolis-s)
Profile
I cant share project stl file.
I dont think thats  profile problem.. its prusaslicer itself failing.
How can you explain that same profile somtimes make good sometimes not..
Shape-Box
Postato : 19/07/2021 10:49 am
Cipis
(@cipis)
Utenti
Missing G92 E0
Add G92 E0 command to the "before layer change g-code" section. It should fix your issue.
Postato : 19/07/2021 1:14 pm
1 persone hanno apprezzato
Karolis S
(@karolis-s)
FIXED
Added option :
G92 E0
Postato : 19/07/2021 1:15 pm
